Tablet PC for DigiArt Major
Discussion in 'What Tablet PC Should I Buy?' started by mbrundi, Dec 14, 2012.
  1. mbrundi
    mbrundi Pen Pal - Newbie
    This is my first post here after much lurking about. I have read a lot of the posts and love the wealth of info on these forums!!! I have recently been looking at the Cintiq... and because of price I starting looking at other options, and found that a tablet pc may be the better choice overall for me anyway! really excited to here some opinions, thanks a lot.
    General Questions.
    1. What is your budget?
    $500-$1000
    yes
    Convertable, windows tab, slate
    5 to7-inches
    7.1 to 10-inches
    10 to 13-inches
    Above 13-inches
    USA
    no
    does not matter
    drawing, art, animation. using adobe photoshop, illustrator, and flash
    no preference, I own a 2008 Aluminum Macbook, but have no gripes with windows. I also recently purchased a Samsung Galaxy Note 2 and LOVE it, although obviously in need of bigger screen and more powerful system to run the necessary applications
    adobe illustrator, flash, photoshop, intended to use "like a cintiq"
    no
    no
    Screen Specifics
    no
    yes, with pressure sensitivity, but if buying a "better" pen separately is a better option, i am open to that as well
    Component Specifics
    not positive on exact specs, it needs to be able to run the above mentioned programs smoothly while being able to draw onscreen. expandable memory/RAM is always nice
    would like usb and maybe hdmi but really would just be an added bonus not needed
    Misc
    thanks again, sorry for showing my lack of knowledge above.
  2. mbrundi
    Point of Info - I am a senior in college, studying digital art, and would be using this device to continue my studies and art. thanks again!
  3. Steve B
    Steve B Moderator Moderator
    3,171
    363
    151
    I would advise reading over the many threads in the recommendation forum for artists such as yourself. Your needs aren't specific (like 3d modeling or something), your budget is appropriate (500-1000$) for used models on ebay, and your opinion about screen size and battery life is flexible too. You can get almost anything. Fujitsu t5010, t900, maybe even a t901 (all 13.3" screens), or the t731, 732, etc. You could get an HP 2730p, 2740p, 2760p, etc. You could get a Lenovo x200t, x201t, x220t. A Motion le1600, j3400, or maybe even a j3500 slate. Or the Asus ep121.
    You've got lots of options, and they all fit the things you've suggested. :)
