Tablet Pc for Architect!!!!!!
Discussion in 'What Tablet PC Should I Buy?' started by damianllilard, Dec 7, 2012.
  1. damianllilard
    damianllilard Pen Pal - Newbie
    General Questions.
    1. What is your budget? Around $500 range or below
    2. Would you consider purchasing used/refurbished? Yes if its a great buy
    3. Do you prefer a media/mobile tablet like the iPad, Windows tablet PC, or notebook convertible? [B]Notebook convertible [/B]
    10 to 13-inches
    Above 13-inches
    5. Which country do you intent to purchase from [where do you live]? NY, USA
    6. Do you have any preferences to brand loyalty or dislikes? No
    7. How many hours battery life do you require? 3-4 minimum but the longer the better
    8. What will be the primary usage scenario of this tablet? Drawing and fixing buildings/Email/Web Surfing/Word Processing/Entertainment/Notetaking but mostly for work.
    9. Do you have an OS preference? For example, do you own an iPhone and a Mac, or are you a Windows fan? Windows Only
    10. What software and tasks do you intend to run? Microsoft Office or other Word Processing Suite/Photoshop/3D Studio Max/Autocad
    11. Do you intend on playing Games? Not really
    12. Would you like to stream content through your home theater system? I'm not sure what this question mean so most likely No??
    Screen Specifics
    1. Any preference on screen resolution? Not really but a decent size mentioned above
    Yes I need to bring it to job sites and make corrections
    Yes I require a pen with pressure sensitivity. I'm new to tablet pc so I'm not sure which is better wacom or n-trig
    Component Specifics
    1. What size Hard Drive and Memory do you require? Would you like expandable memory? Not that important as long it holds my notes and building corrections
    2. What sort of inputs do you require, if any? Would you like full-sized USB and SD card slots? Are microUSB and microSD ok? Do you require HDMI inputs? It would be nice to have those features for storage purpose and I don't require hdmi
    I need to buy a convertible tablet pc for my father this christmas since he is an old school type of arichtect, He's been struggling at work because of the advancement in technology. Back in his days, architect used their hands and skill to design buildings. And I believe a convertible tablet pc is the perfect gift for him.
    THANK YOU SOO MUCH FOR READING THIS AND FOR YOUR INPUT/SUGGESTION,
    Damian
  2. drvenom
    drvenom Scribbler - Standard Member
    152
    For that price, you are going to have to get a used one. I would look on ebay.
    I would go for the hp 27xxp series. I would probably try to find the hp 2740p since it has touch capabilities as well as a wacom digitizer. In addition, it is light, thin, and will handle the apps that you need to run. If you can't find the hp 2740p for that price, you can get the hp 2730p, but this one does not have touch capabilities. It only has the wacom digitizer which is great for writing and drawing.
  3. damianllilard
    thanks for your input drvenom...this there any other brands out there that fits under my requirements??
  4. damianllilard
    So I just checked some of the reviews on the hp 2740p and didn't seem to find it appealing. I think my requirements for a tablet pc is pretty straight forward and basic. As I mentioned earlier, my father is a simple guy and just need to mark corrections and draw on photos of buildings while being able to use it as a laptop.
    There's got to be other models out there and I really appreciate any help possible because I need to buy this gift soon before Christmas. :confused: :rolleyes:
  5. stoneseeker
    3,446
    863
    What about the HP 27xxp series do you find unappealing?? those have a pretty high rep in these forums.
    The only other convertible tabletPC's to look at are Lenovo X201t, X220t, and X230t (last 2 out of your price range)
    and Fujitsu T900, T901 and T902 (also last 2 out of price range)
    For the requirements you listed those are the convertibles people will first recommend. In fact I don't know of any others, except much older models from Gateway and Toshiba.
    Everything new these days is mostly hybrids and slates.
  6. damianllilard
    thank you soo much for that list of suggestions stoneseeker. i just wanted to make sure that the tablet pc i'm going to purchase will last for a while. hearing reviews about random reboots, touch pad problems, and battery life kinda worried me a bit. but i will look into the other tablet pc convertibles that you mentioned :thumbsup:
    also what do you think about the lenovo x61/x61t?? didn't do much research on it yet but it looks pretty durable with long battery life.
  7. stoneseeker
    3,446
    863
    It's a fair amount older, but from what I understand they were built like tanks, and they were very highly regarded. However, at the age they are at now, finding one with a decent battery is going to be tricky. You may have better luck with the x200t or x201t and they will be faster too.
  8. damianllilard
    i see...i was looking into the fujiitsu models that you mentioned earlier stoneseeker and was wondering how sturdy is the keyboard since my father needs to be able to feel the keyboard when he types if you know what i mean.
  9. stoneseeker
    3,446
    863
    I can't speak to the older ones, but the T902 feels great. It's very tactile, lots of spring and feedback. I'm not terribly picky though.
    The Lenovo's- especially the older models- will have the best keyboards... they are quite renowned for their keyboards. All of these machines listed will have better than average parts, as these are all high end business class devices, not casual consumer grade stuff. So I imagine the keyboards will all feel a step up from an average cheap laptop or something.
  10. damianllilard
    i see thanks for letting me know....does anyone know any good websites to purchase some of these tablet pcs from?? i'm asking because i can't seem to find some of these models online...thanks :thumbsup:
