Tablet PC for an Artist ?
Discussion in 'What Tablet PC Should I Buy?' started by Roxugami, Nov 11, 2018.
  1. Roxugami
    Roxugami Pen Pal - Newbie
    General Questions.
    1. What is your budget?
    I'll spare no expense if it's good enough, but I'd like to spend less than $1500
    No, just new
    I'll need to use it as a primarily a tablet and a laptop secondarily; I've used the Surface Pro 4 for the last 2 years but the jumpy pen issues arose near the end and became too much to handle.
    • 5 to7-inches
    • 7.1 to 10-inches
    • 10 to 13-inches <---
    • Above 13-inches
    USA
    I'm reluctant to stay with Microsoft Surface bc of the cursor issues while using the pen (it was a common issue with SP4 as far as I've researched), but if those problems are fixed in newer or different versions I'd stay.
    4/5 hours at least.
    Drawing; I like to have it on my lap while around the house or out somewhere. I enjoy portability.
    I'll need this to work with my Clip Studio Paint license (so not iOS or Android), and preferably compatible with the Wacom Bamboo Ink stylus.
    Clip Studio Paint, and possibly other animation and designing software
    Not really
    Nope
    Screen Specifics
    above standard
    I'll rarely use it outdoors, but occasionally I will, so that might be nice.
    If it's not compatible with my Wacom Bamboo Ink, I will need a new pen. As long as it works well, I don't care about what kind it is.
    Component Specifics
    8-16GB; doesn't need to be expandable.
    full USB slots, nothing more.
    Misc
    A decent processor.
    That's all folks
    artistebot likes this.
  2. Kumabjorn
    4,604
    2,927
    Sounds like the HP Folio is something you at least should take a look at.
  3. artistebot
    462
    436
    IMHO:
    The best Tablet PC is the HP Zbook X2. It uses Wacom EMR so is compatible w the Wacom Bamboo, but frankly the stylus it comes with is better. The Zbook might be overkill for what you need but it runs CSP very, well. In many ways it is better that a Wacom Mobile Studio Pro.
    I highly suggest you read through this thread on this forum concerning this device:
    http://forum.tabletpcreview.com/threads/zbook-x2-just-announced.73074/
    Also have a look at this wiki on Reddit:
    https://www.reddit.com/r/stylus/wiki/index
    You are correct to stick with a device the is compatible with your Wacom Bamboo. Essentially a "EMR" device. There are several "pen" technologies, but frankly Wacom EMR is by far better than all others, followed by Apple Pencil. IMHO if you are used to Wacom products that you will likely find the other options lacking.
    A few other options:
    Samsung GalaxyBook 12
    Acer Switch 7 (apparently very rare and hard to get outside or Europe, possible terrible battery.)
    Samsung Notebook 9 Pro
    FYI there is a version of Clip Studio that runs on iPad Pro...
    Whoops, I have the EMR Wacom Bamboo., and totally forgot about the other one! Never mind the rambling..
  4. DRTigerlilly
    7,596
    751
    301
    stick a pin guys, isn't the Wacom Bamboo Ink an AES/MPP pen? Not an EMR Pen that would be Wacom Bamboo Stylus Feel or Carbon etc....
    Roxugami and artistebot like this.
  5. Roxugami
    My bamboo ink stylus isn't EMR. it can switch between AES and MPP though
  6. etoons
    etoons Pen Pal - Newbie
    67
    18
    I think you may want to just try out the new surface pen, not the Wacom bamboo ink. From my experience, the bamboo ink is a bad pen that has soooo much pen jitter. Not sure if it will fix your issue, but it's worth a try, and cheaper than getting a new device. If it doesn't fix ur issue, you could always return it.
    Sent from my LG-H830 using Tapatalk
  7. Azzart
    2,342
    1,726
    I still consider it the best tablet pc for drawing I've ever had, particularly coupled with the Staedtler Noris. :)
    DRTigerlilly likes this.
  8. DRTigerlilly
    7,596
    751
    301
    That's interesting, many have experienced the opposite, that the Bamboo Ink helped to alleviate the jitter observed with the new Surface Pen. That seems to be caused by some interference, as many observe it if they're touching the metal back of the device.
    That said, with the last update (that was initially problematic for some) 1809 users were initially reporting improvement with the jitter.
  9. DRTigerlilly
    7,596
    751
    301
    The good thing is that the EMR devices like the Galaxy Book come with it's own stylus.
    Many artists believe Wacom Pro EMR (Cintiq)>Wacom Penabled EMR> Apple Pencil > Wacom AES> MPP/Ntrig
  10. etoons
    67
    18
    Really? That's pretty odd. This video basically shows what I experience using that bamboo ink
    For me, the surface pen works much better, but by far, EMR is the best. I use the surface for school, since it's very portable and light.
    yodamiked likes this.
