tablet for taking notes
Discussion in 'What Tablet PC Should I Buy?' started by ultra99, Jun 20, 2018.
  1. ultra99
    ultra99 Scribbler - Standard Member
    152
    General Questions.
    1. What is your budget? $400 cad
    2. Would you consider purchasing used/refurbished? yes
    3. Do you prefer a media/mobile tablet like the iPad, Windows tablet PC, or notebook convertible? ipad/windows
    • 5 to7-inches
    • 7.1 to 10-inches I prefer 10" ( i had the surface gen 1 and it was great!)
    • 10 to 13-inches
    • Above 13-inches
    5. Which country do you intent to purchase from [where do you live]? Canada
    6. Do you have any preferences to brand loyalty or dislikes? none
    7. How many hours battery life do you require? doesn't matter
    8. What will be the primary usage scenario of this tablet? (Email/Web Surfing/Drawing/Word Processing/Entertainment/Notetaking etc) note taking using OneNote
    9. Do you have an OS preference? For example, do you own an iPhone and a Mac, or are you a Windows fan? Do you own an Android device and use Google services frequently? windows or iOS
    10. What software and tasks do you intend to run? (Microsoft Office or other Word Processing Suite/Photoshop/3D Studio Max/Autocad etc) OneNote
    11. Do you intend on playing Games? If so please list. no
    12. Would you like to stream content through your home theater system? no
    Screen Specifics
    1. Any preference on screen resolution? none
    See the above linked FAQ for guidance yes
    Component Specifics
    1. What size Hard Drive and Memory do you require? Would you like expandable memory? NA
    2. What sort of inputs do you require, if any? Would you like full-sized USB and SD card slots? Are microUSB and microSD ok? Do you require HDMI inputs? NA
    Misc
    I have the Thinkpad X1 tablet 1st gen but I find too big and overkill. I like the 10" on the MS surface 1st gen. I've tried several sizes 7-12" but find 10-10.6" the sweet spot. I use an iPhone and a Windows PC, so the tablet can be either an ipad or windows 10 but WITH A PEN.
    I want to sell the X1 tablet, it's just too overkill.
  2. Bronsky
    7,682
    4,143
    Refurbished Galaxy Note 10.6's are selling for around $300 - $350. Probably your best option in a 10" tablet. There is a new 10" surface coming that might be worth the wait.
    WillAdams likes this.
  3. pigeontongue
    pigeontongue Pen Pal - Newbie
    74
    Settle for Cube i7 book and it's working very well. It is affordable windows tablet with a pen.
