Tablet for note taking (400-500€ budget)
Discussion in 'What Tablet PC Should I Buy?' started by metk97, Apr 26, 2017.
  1. metk97
    metk97 Pen Pal - Newbie
    Hi everyone!
    1. What is your budget?
    400-500€ or less
    I would prefer new. But used or refurbished would be ok if the product has still some kind of warranty.
    I'm looking for a windows tablet (because on One Note) with a digitalizer.
    Also a 2-1 would be ok.
    • 5 to7-inches
    • 7.1 to 10-inches
    • 10 to 13-inches
    • Above 13-inches
    I live in Italy, but i'm willing to buy from all the UE if the product has an International Warranty.
    Absolutely not
    8 hours or more
    I'll basically use it only with an active pen for take note during lecture, and for pdf reading, also some light web browsing.
    I need a windows tablet, because i've never find a good One Note-like app in Android or IOS
    I need it to works flawless with One Note
    No
    Also no
    Screen Specifics
    No
    No
    Yes, i need a good pen, and i have no preference between the two, i only need it to work reallty well
    Component Specifics
    I would prefer 64gb or higer, with expandable memory
    An USB port would be appreciated, but i don't have any strict demand
    Misc
    I need it to last at least 2-3 years with no problem with One Note. I don't really care about the other things; my main use would be note taking with One note.
    I have considered the surface pro 3 and 4, but they cost too much in the UE. I've also seen the Asus Transformer Mini (T102HA) it seems ok but i don't like too much the processor.
    Thanks to everyone!
