Tablet for filling out ODK forms
Discussion in 'What Tablet PC Should I Buy?' started by alliusis, Jun 5, 2021.
  1. alliusis
    alliusis Pen Pal - Newbie
    General Questions.
    1. What is your budget?
    We will pay as much as we need to, but this is for a registered charity so ideally lower than 500-700 if possible.
    Yes absolutely
    We don't need it to be anything fancy, just something that can reliably fill out ODK forms and manage data (excel, google sheets, etc).
    • 5 to 7-inches
    • 7.1 to 10-inches
    • 10 to 13-inches
    • Above 13-inches
    Canada
    Nope, as long as it works.
    Ideally it will be plugged in when not in use, but I guess 4-5 hours would work OK.
    Used to fill out a daily health checklist (using ODK forms) at an Aviary I volunteer with. Potentially fill out other forms such as tracking toys, etc.
    No preference, whatever works.
    Outside of ODK, potentially Excel and/or Google Sheets and other basic data management programs.
    No.
    No.
    Screen Specifics
    No.
    No.
    No, probably not.
    Component Specifics
    32 GB should be fine. We are aiming to upload the data up to the cloud at least once weekly.
    No important inputs.
    Misc
    Something not too delicate -something that fits into common drop-resistant/child-proof cases. The following isn't necessary, but if there's a tablet that interfaces well with some kind of locking system (to protect against theft) that would be great.
    Needs to have a back-facing camera. Having a kiosk mode would great as to not confuse or frustrate some technologically-challenged crew leaders.
    Thanks!!
