Tablet for artist
Discussion in 'What Tablet PC Should I Buy?' started by hohnir, Aug 10, 2012.
  1. hohnir
    hohnir art hobbyist
    I'm a first time buyer so please be nice.
    1. What is your budget?
    Under $300. Shipping not included.
    Sure.
    Preferably a notebook convertible. But a slate will be "ok".
    5 to7-inches
    7.1 to 10-inches
    10 to 13-inches ----this!
    Above 13-inches
    Asia - Philippines
    I'm not sure about HP. My friends told me it's not good to buy from them : CS sucks, products don't last, etc. Feedbacks are not good.
    Even nameless brands are ok as long as it is durable. But preferably, Asus, fujitsu.
    2 hours up.
    Painting, Drawing, college student type activities
    Windows is good.
    Photoshop CS4. Must not lag.
    The Sims 3 IF possible.
    Nope.
    Screen Specifics
    WXGA (1280x800). I need space.
    Yes. I'm currently using a Dell Vostro 1014. The glare is annoying. As long as I can see it's fine. Can't be too picky.
    Pen - with pressure sensitivity - Wacom
    Component Specifics
    2GB RAM
    120 HDD UP
    expandable memory not really needed then again it's still a plus
    Only need USB, the rest I can live without.
    Misc
    Additional battery is a +
    Responsive screen is a must. I've tried a graphics tablet but I don't like the hand to eye coordination.
    Older models are ok - say 3-4 years. I want the likes of ASUS R1E~~quite rare.
  2. stoneseeker
    3,412
    841
    I think the Asus R1E has a reputation of burning a hole in your lap? Not really sure about its build quality either...
    The old Fujitsu's are your best bet. In Ebay you can save searches and be notified when certain items are put up for sale internationally so you can snatch them before anyone else does. You would do well to find a T5010 in your price range, if your willing to go used. HP2730p might be an option, or any other HP elitebook convertible used that reaches your price range. some of the older Lenovos too, like the X200T, X201T, X60...
    good luck!
  3. hohnir
    hohnir art hobbyist
    Thank you. I found a cheap NEW X201T , too bad it's still in bidding process.
    Can't believe it's i7. Wow.
  4. Shogmaster
    3,755
    1,050
    If it's still bidding, it will end up north of $400.
    You are looking at Core 2 Duo machines for south of $300.
  5. hohnir
    hohnir art hobbyist
    One can hope. ;) 2 days more.
  6. Shogmaster
    3,755
    1,050
    The cheapest X201T has sold for was $450 in the last couple of months. 2 days is forever on Ebay. You should make another plan.
  7. hohnir
    hohnir art hobbyist
    Yeah I do.
    Any more tablet suggestions?
    Thank you.
  8. Steve B
    Steve B Moderator Moderator
    3,156
    353
    151
    HP 2730p, Lenovo x200t, or the Fujitsu 4220 are good bets. These are three good models and can be got for right around 300$ sometimes nowadays on Ebay. HP may have a bad rep for its consumer models, but there's almost universal praise for its high end models like the tablet pcs. The x200t is a solid machine as well. My understanding is the Fujitsu is too. All are dual core machines, and all take atleast 4 gb ram-- a couple of them take up to 8. All are Wacom too. These are the sorts of machines that'll fit in your budget, but the truth is they're good machines anyways.
  9. hohnir
    hohnir art hobbyist
    Thank you. How about this one? I'm not sure if this one includes a stylus. Also, is it a WXGA and wacom support?
    Lenovo ThinkPad X200
    EDIT : nevermind. I know now.
  10. hohnir
    hohnir art hobbyist
    HP 2730p :
    HP Elitebook 2730p Tablet PC Review
    FUJITSU T4220 :
    Fujitsu LifeBook T4220 Tablet PC User Review
    These are the two that I finally choose within my budget.
    Thank you for all the feedbacks.
    Questions :
    1. Which is better for artist? I am going to use Photoshop CS4 and Paint tool Sai.
    2. How responsive and accurate is the stylus?
    3. Should I pick the HP 1.8 ghz core 2 duo 120gb over the 80gb 2.2ghz core 2 duo of the Fujitsu? ---I'm not sure which has better performance. Please enlighten me.
