t732 lifebook
Discussion in 'Fujitsu' started by arolust, Dec 8, 2015.
  1. arolust
    arolust Pen Pal - Newbie
    I recently bought a T732 off ebay, and I have a question about one of the back cover panels, its at the top left, just beneath the battery. What is this slot for?
    EDIT:
    Nvm, found the youtube videos, its a pci slot.
  2. utopian201
    199
    14
    I have a T734 (which is basically the same) and it can only fit WWAN cards; I asked Fujitsu if an ssd (mpcie or msata) can be installed to that slot and they said no.
  3. Starlight5
    Starlight5 Yes, I'm a cat. What else is there to say, really?
    676
    221
    @utopian201 did you actually try it? Tech support knows nothing, usually. It is an m.2 2242 b-keyed slot, meaning m.2 2242 sata ssd, or msata half-size ssd via adapter, may work. I'd definitely give it a try if I had one.
  4. arolust
  5. utopian201
    199
    14
    No, it wouldn't make sense to buy one to try if they said it doesn't work. If I had one for free I'd try. I don't think the slot is a sata compatible because the slot is used for the wwan slot (mpcie). I don't think a slot can be electrically compatible with both sata and mpcie.
  6. Starlight5
    676
    221
    @utopian201 b-keyed m.2 is actually all about that. I ordered a dirty cheap m.2 to SATA adapter - we'll know for sure when it arrives.
  7. utopian201
    199
    14
  8. dschad
    dschad Pen Pal - Newbie
    25
    Did you get yours from playitagainpc? Which type of damage did you buy? They have a bunch of listings, some with "screen damage" and some with "case damage" and some with both. Prices differ within $10-$15, but I can't tell which gives me the best chance of getting a good machine (more expensive ones have screen damage, which sounds worse then case damage). I asked the seller about price differences/versus quality and got a completely unclear answer. To me it looks like the best machines cost less?
  9. arolust
    This is a bit late, but if you still need to know, or if others are thinking same.
    I got one that said "case damage". Mine has marks and scratches on case, but no other damage (screen much harder to fix or anything, so case damage probly best).
    Rondo60 likes this.
