T732 (8.1 Upgrade) Buttons don't work
Discussion in 'Fujitsu' started by cookies4you, Oct 20, 2013.
  1. cookies4you
    cookies4you Scribbler - Standard Member
    214
    44
    After installing 8.1, my Tablet buttons have appeared to stop working.
    The Windows button, as well as the 1-4 and the ENT buttons simply aren't responding.
    Anyone know how to fix this?
  2. cookies4you
    214
    44
    Well, after installing the Pointing Device drivers, I've managed to get the buttons working again.
    However, I'm missing the Fujitsu Tablet Controls utility, as well as the one that allows me to set my display profiles.
    This means that since I can't choose my profiles, tablet mode is now broken, since the touch keyboard won't pop up anymore.
    EDIT:
    From what I'm getting, 8.1 seems to have broken the Fujitsu System Manager software.
    Trying to reinstall gives me an error, even thought it does successfully install itself.
    Not sure what you're pulling here, Fujitsu...
  3. utopian201
    199
    14
    oh no, I've just started to update mine to 8.1 I will let you know how I go.
  4. monkey13
    monkey13 Scribbler - Standard Member
    114
    27
    Mine is working fine after the upgrade to W8.1. However I had to reinstall the System Manager, the pen didn't work afterwards.
    Look on the support page, http://support.ts.fujitsu.com/download/ShowFiles.asp there are some new drivers for us there (Device Driver category), inculding a pointing device utility, wireless switch, FUJ02E3 and B1 driver. It seems that those needed an upgrade. Maybe try reinstalling those if you have problems.
  5. utopian201
    199
    14
    hhmm, yes I haven't updated the drivers yet, but I found the two finger scrolling worked flawlessly before the upgrade, but now you need to slide your fingers momentarily before it starts scrolling - previously it was instant.
  6. monkey13
    114
    27
    Just a quick note: be sure to check the driver page for the T732, as I looked only on the one for the T902, but I guess they made some changes to those drivers for both models.
  7. utopian201
    199
    14
    how did you get the file system manager installed? When I try to run the msi or setup.exe, it says "The operating system is not adequate for running Fujitsu System Manager"
  8. cookies4you
    214
    44
    You should scroll down a bit.
    There are Windows 8 32-bit and 64-bit variants, so you may have downloaded the wrong ones.
    The same applies to the Windows 7 drivers, which are a lower.
  9. monkey13
    114
    27
    I didn't have any probs installing the system manager. As cookies4you says, be sure to install the proper one for your OS. Mine was the x64 one.
  10. Steve B
    Steve B Moderator Moderator
    3,410
    581
    So, in the end, did you get 8.1 working properly? I'm getting a t902, and would like 8.1 on it. I know they're not exactly the same device, but they're close. Thought I'd check. If you guys have it working right for the t732, it'll probably work right for me with the t902.
