T5010: changing default orientation in slate
Discussion in 'Windows Vista OS' started by Gwi, Jul 27, 2009.
  1. Gwi
    Gwi Pen Pal - Newbie
    21
    I've been looking everywhere for this but haven't found a solution yet. Right now it automatically rotates to primary landscape when I flip the screen on its back, but I only use the secondary ones. I tried to change the order in the tablet options, and I didn't even select any of the primary ones. Could anyone help me out with this?
    Thanks!
    Dieter
  2. frog
    frog Scribbler - Standard Member
    290
    Put it in slate mode, then in the orientation you want.
    Open Control Panel --> Fujitsu Tablet Properties and save the current profile.
  3. Gwi
    21
    It's so simple. Thanks frog!
  4. frog
    290
    No worries :D
