T4220 v T2010 for sweet silence?
Discussion in 'Fujitsu' started by jimdab, Mar 23, 2008.
  1. shoebox9
    shoebox9 Pen Pal - Newbie
    Hi Folks,
    I suffer from a medical hearing issue- tinnitus triggered by fan (and even h/d) noise. My desktop box is through a wall, and I'm after a totally silent tablet (during reading/study) to compliment this. (I'd swap in a SSD)
    Should I buy: T2010? From threads I've been able to find here, it seems this guy runs fanless during low CPU tasks :) but is very loud if you do tax it.
    Or T4220 with Penryn? The Penryn version is listed on the Australian site and should be available here in 3-4 weeks according to vendors. Heat output with the Penryns is supposedly >50% less than the same Intel CPU clockspeed at 65nm, which is simply amazing.
    If the current T4220s with their performance/battery controls cranked right down can almost run low CPU tasks without fan now ????? I'd choose this. QUESTION: Can they???
    Thanks in advance :)
  2. rnode
    rnode Pen Pal - Newbie
    52
    An ssd should help a good deal. The optical drive in the T4220 will spin up at times and the machine will be noisier as a result with the optical drive inserted, so the 2010 might be bettter as it does not have a builtin optical drive. You can put a blank in the T4220 I believe, which would give you the same result.
    As for fan noise, I recall seeing a thread where some were able to reduce fan noise, I thought it was the Vista sp1 thread, but after checking again, it wasn't. Maybe, I was dreaming. I'll check my bookmarked threads and see if I can find it.
    Someone with a T4220 will have to comment on how well they clock down and reduce fan noise. It seems to me, that unless you really want the most battery life possible and a somewhat lighter/smaller tablet, the T4220 is probably your best bet. This comes from someone who bought the T2010 :) ... but battery life and small size were high priorities for me.
  3. robdam1001
    robdam1001 Scribbler - Standard Member
    198
    I have NEVER heard my T2010 fan run. It's a very quiet machine IMO.
  4. mederis
    mederis Pen Pal - Newbie
    If you want absolutely no fan, T4220 is probably not for you. When I bought it about half a year ago, it was the only combination high res screen / high power cpu tablet there was. I think it might still be. The trade off is that it's not absolutely silent, and battery is average. In Power Saver mode it's very quiet, but if you put your head near the laptop, you can hear the low hiss of the fan. In High Performance, of course it's very noticeable. There's also a "whining/buzzing" sound that comes from the cpu in High Performance when you're running on battery, but apparently that's a T7700 issue common to all laptops with that cpu. If anything would trigger your tinnitus, I would think that would do it! It doesn't bother me much anymore (and while on battery I'm usually on Power Saver anyway), but initially that really annoyed me because it's a high pitched sound.
    Maybe the Penryns will improve this.
  5. SimsHsia
    3,293
    There's a setting in the T4200 series BIOS where you can switch the fan setting from "Normal" to "Quiet". I'm still experimenting, but I hardly hear the fan on this setting, but it was slightly noticeable on the normal mode setting -- at least it doesn't sound like my old laptop that sounds like a jet engine when idling! :D
    I agree with mederis that with Power Saver the fan is quiet, even when on Balanced mode -- however these are my observations with the fan on "Silent" mode.
    Yes, the T4200 series has a "weight saver" that rnode is describing where you can remove the optical drive and put that in, or a modular bay battery for extra battery life.
  6. phuoc
    phuoc Pen Pal - Newbie
    i have the t4220 on normal mode and also put in under full load during games^^ as far as i can tell, yes u can hear the fan but for me its very silent. if u would have something like that for full upgraded desktop pc, hell i would buy it :) as comparison, the harddisk is louder than the fan, but the fan isnt completely silent, its a fan ^^.
    have to correct myself...100% cpu load for more than 10mins results in a remarkable noise, not rly loud but definitely too loud for u. so if u dont stress the system the t4220 is fine for u, otherwise better listen to the 2010 users.
  7. Frank
    3,847
    116
    I think both machines are equivalent loud.
    The T4220 gets hot, the T2010 is only warm.
    It's like you already said. If you don't stress it and it isn't connected to an AC-Adapter, then it is silent. But if it is connected to an AC-Adapter, then the fan kicks more often on even while not doing some CPU intensive stuff.
  8. shoebox9
    I think that's mainly a yes to total silence on the T4220 (my prefered option) IF I swtich the optical drive for a battery, and keep it on battery while reading- all with "silent mode" selected in BIOS, the CPU underclocked (if that's possible), and nothing too hungry running ???
    (Sadly "very quiet" isn't enough to keep my ears from ringing at night- it needs to be dead silent. Traffic noise is fine, but not constant medium/high pitched sounds.)
    Some say yes, some say no ? Is the T2010 my only really safe bet?
    (BTW, thanks a heap.)
  9. shoebox9
    Hi Mederis,
    Are you sure it's the fan noise you're hearing, and not the H/D? When it's cold it should run with fan off for a while (and only make the h/d whoosh noise). My question is when going all out, how long will the fan stay off?
    This is a great forum BTW. You tablet guys are really interesting and I'm looking forward to joining your ranks. :)
  10. powowcow
    powowcow Tablet PC Lover
    197
    Bose Quiet Comfort 2 Headphones
    Sweet silence indeed!
