T2020 screen type and quality
Discussion in 'Fujitsu' started by KenK, May 27, 2009.
  1. KenK
    KenK Pen Pal - Newbie
    85
    Does anyone know if the T2020 uses a TN or PVA panel? The review here says it has a "great view angle," but is the view angle at least as good as the Lenovo X200t (which reportedly has a PVA panel)?
  2. Frank
    3,847
    116
    I don't know exactly what type of display Fujitsu uses, but they definitely don't use a TN display, because the Fujisu displays have wide viewing angles, and a TN display has very limited viewing angles.
    To be honest, I can't tell you the angle I have to tilt the display until I see a difference in the image, it's impossible for me.
  3. zephir
    zephir Pen Pal - Newbie
    I don't know about T2020, but T2010 uses the best panel ever created for a notebook (even better than Samsung PVA panel used in X200t). The panel is BOEHydis Hv121wx6
  4. Frank
    3,847
    116
    How do you know this number?
  5. zunq
    zunq Scribbler - Standard Member
    309
  6. KenK
    85
    Thanks for your responses. Sounds good to me.
    My new T2020 should arrive next week.
  7. zephir
    I opened mine up ;)
  8. hydrocyanic
    hydrocyanic Pen Pal - Newbie
    42
    since viewing angle is 89/89 for both V/H direction i am positive that it is an IPS unit. i believe only ips does that, and it has a 18bit interface too :)
    add: nm... 18bit is just the normal 262k color :(
    very unfortunate to hear thinkpad x200t uses a mva panel :(
  9. Colourful Zone
    Colourful Zone Using T2020 thru DIY e-PCIe I/F, now using T904
    25
    In fact, the panel of T2010/T2020, I am currently using T2010 :), is the widest display angle display panel I saw so far. You can clearly see the screen content at any angle.
  10. KenK
    85
    I agree the T2020 display is among the best, if not the best, for a tablet PC. But it's still a bit of a stretch to say you can "clearly see the screen content at any angle." If I lay it flat on a desk/table, I find I still need to sit up straight and look down on the display. I guess I'm spoiled by the eInk display on my Kindle - I won't be canceling my Kindle-DX order after all, even though I plan to use it strictly as a PDF viewer.
Similar Threads - T2020 screen type
  1. Steve S
    705
