T2010 gives off buzzing sound...
Discussion in 'Fujitsu' started by Rommie2k6, Aug 10, 2008.
  1. Rommie2k6
    Rommie2k6 Scribbler - Standard Member
    380
    I've just noticed that my T2010 gives off a buzzing sound. Very faint sound, didn't notice it until today when I was in a quiet environment. Is this normal?
    I think something is wrong with the AC Adapters (emphasis plural). Previously I posted about the static shock I've been receiving. I think they're due to the 2-pin design of the AC Adapter, lack of grounding to be precise. FYI, I'm using a US AC Adapter in Singapore (240V, UK-plug).
    Does anyone know how to fix it? Should I get both AC adapters replaced?
  2. Rommie2k6
    380
    Ok, the buzzing still exists when running on batteries.....
  3. dmlerner
    dmlerner Scribbler - Standard Member
    109
    If it's an extremely high pitched noise, then it's inherent to core 2 duos, and there is nothing you can do about it. Mine does that, but it's pretty tolerable.
  4. Frank
    3,847
    116
    not only Intel C2D are affected even some AMD laptops. But it's "normal", at least you can't do anything against it.
  5. Rommie2k6
    380
    Ok. Thanks for the clarification. Wonder why Core Duo 1 (Yonah) never had this problem?
  6. aptyu
    aptyu Pen Pal - Newbie
    seems no way to reduce the noise...
  7. leaftye
    4,127
    I believe there are some settings you can use in RMClock to get around the circumstances that cause the buzzing. Supposedly it has something to do with how the processor steps up and down to save power.
  8. thrawn86
    thrawn86 Pen Pal - Newbie
    45
    funny you should mention buzzing noises, my t2010's fan is starting to give off a pretty annoying buzzing sound even at the lowest fan levels.
  9. Edwood
    Edwood Scribbler - Standard Member
    364
    If it's anything like my P1610, it's the inverter for the backlight for the LCD display. It buzzes when it's not running at full power. So that's the reason why you are only hearing it on battery power, as your power saving features dim the backlight by default to save power. When you are on battery pwer, try cranking the LCD brightness all the way up (usually Fn key + ^Brightness).
    You'll sacrifice battery life, but it will be silent.
    -Ed
