System Recovery vs Minimized Image Recovery
Discussion in 'HP TouchSmart TM2 (Wacom)' started by nordloewelabs, Apr 21, 2010.
  1. nordloewelabs
    nordloewelabs Scribbler - Standard Member
    156
    there's an unusual option on the tm2's Recovery Manager: "Minimized Image Recovery". does anyone know what that is? when i click on it, it takes me to a window that is identical to the one displayed if i had choosen "System Recovery", instead.
    UPDATE: so i decided to go through the process of recovering the system using both methods, just to compare the results. here is the story. the "Minimized Image Recovery" option takes a lot longer (it seems to install each application and driver individually, instead of dumping an image to the drive), but it's worth it. at the end, after almost 2 hours of wait, you get a less bloated system. obviously, the resulting installation isnt as slim as a clean system install with the Windows disc.
    Code:
    |                         | SYS RECOV | MIN SYS RECOV |
    | Installation length     | 40 min    | over 90 min   |
    | Files in C:             | 141,000   | 86,500        |
    | Programs installed      | 79        | 40            |
    | HD usage                | 33.3 Gb   | 26.3 Gb       |
    | RAM usage (after 5 min) | 993 Mb    | 844 Mb        |
    | Processes (after 5 min) | 74        | 62            |
    | Boot (logon)            | 40 sec    | 35 sec        |
    | Boot (Launch IE)        | 56 sec    | 44 sec        |
    | SU7300 1.3GHz, 4Gb RAM, ATI, Windows 7 Home Premium |
  2. adam.mt
    960
    Thanks for your efforts. Very useful information, sure it'll help many others.
    (repped)
  3. BlindWolf8
    BlindWolf8 Comparer of tm2s
    285
    I also did both before you had this post. The Minimized Image Recovery was nice, (and did take a long time as you noted) but I found something odd with it: pen AND touch would work fine, but after the first reboot pen works, but touch DOES NOT. Tablet PC Settings in the Control Panel also goes missing. It's all very odd.
  4. nordloewelabs
    156
    hmmmm, that didnt happen to me. what i did notice with reboots is that in the first 3 boots, boot times were 2 min long. by the 10th or so boot, the time had halved.
    i'll have the Minimized Image Recovery done again in the next days and i'll pay close attention to the touch problem you mentioned.
  5. BlindWolf8
    285
    Thanks for taking a look! Any specific reason you keep resetting your system?
  6. nordloewelabs
    156
    because it's not my main system yet and i want to learn its quirks before i move my progs and tasks to it. so basically, i'm on learning mode. i'll eventually abandonon both recovery methods and perform a clean install.
    also, my HD vibrates too much and i'm getting a replacement one shipped next week.
  7. BlindWolf8
    285
    Completely understandable. Btw, what hard drive do you have? Some machines have a WD drive, while others have (I think) a Hitachi.
  8. nordloewelabs
    156
    i have only heard of the Seagate ones (my case).
    maybe the WDs and Hitachis were shipped in Jan-Feb.
  9. AEDan1977
    AEDan1977 HP Tablet User
    I believe the problem is that the "Tablet PC Input Service" is Disabled or set to Manual.
    To Re-Enable:
    1. On the Keyboard: Press and Hold WINDOWS FLAG KEY + R to bring up the run dialog box and release the keys
    2. Type: "services.msc" and Click "OK"
    3. Scroll Down and look for "Tablet PC Input Service"
    4. Right click on "Tablet PC Input Service"
    5. Click on "Properties"
    6. Under "Startup Type", change it to "Automatic"
    7. Click "Apply"
    8. Click "Start"
    9. Click "OK", this should close the Tablet PC Input Service window
    10. Close out of the main Services panel with the X in the upper right corner
    11. Click the "Start Button" and "Restart" the HP tm2 laptop
    Once the computer is rebooted you should have full Tablet functionality. You will have partial functionality before you reboot after starting the service, but everything won't work correctly until you actually reboot the computer to restart windows 7.
    - Dan
  10. nordloewelabs
    156
    strange.... it just happened to me. the previous 2 times i did the "Minimized Image Recovery", the touchscreen worked fine..
Similar Threads - System Recovery Minimized
  1. DRTigerlilly
    151
