Surface Pro X Discussion Thread (October 2019)
  1. Azzart
    2,240
    1,560
    Considering they didn't even port the full Photoshop experience in iOS I would be very cautious about that commitment. ;)
  2. darkmagistric
    2,672
    1,803
    ...while that is true and so disappointing.....its still something.....but also Windows on ARM.....is at least running Windows....from the file system, etc.....I would hold out more hope for a more faithful build then they did with iOS.
  3. JoeS
    5,067
    3,194
    Something that we haven't discussed much is the fact that this Pro X doesn't have a prop-up keyboard anymore. There doesn't seem to be a way to fold the front edge up against the display for stability. [edit: apparently it does prop up, see next post]
  4. darkmagistric
    2,672
    1,803
    It does....I do recall seeing a few videos of it today where the keyboard did prop up perfectly fine....might not be the same angle as the Pro 7....but it does prop up.
    JoeS likes this.
  5. JoeS
    5,067
    3,194
    Huh, surprising! The side-view that's now in the first post of this thread makes it seem like it wouldn't be flexible enough to fold up. So if it does, that means you could use it with the pen out of view, flipped up against the display? I kind of like that!
    Edit: you're totally right, picture stolen from Ars Technica
    darkmagistric likes this.
  6. dellaster
    dellaster On Hiatus Senior Member
    1,283
    1,048
    They’re trying to one-up Apple! :eek:
  7. dceggert
    3,092
    532
    Yea, but think how much you will save in batteries until you lose it in 5 months and need another one. But you won't need batteries for that one either so you actually are saving! :rolleyes::cool:
  8. JoeS
    5,067
    3,194
    According to Microsoft's specs, under typical use the Surface Pro X gets 13h of battery life, compared to 10.5h for the Surface Pro 7. That's 24% more battery life. Definitely nice to have, but not shockingly more than the 7. The X is a whole 1.2mm thinner, 0.04 lbs lighter, and has a whopping 8% more screen area. It's going to be hard to decide between the two.
    - Need LTE? Pick the X.
    - Need most compatibility, pick the 7.
    - Need a little more battery life? Are you sure? OK, the X.
  9. dstrauss
    10,058
    8,247
    Check out The Verge hands on of the Surface Pro X and Surface Pro 7 - there is a little tray under the kickstand that you pop off with the little sim tool (looks like an open paperclip) and it uncovers the SSD and a SIM slot - nomSDX slot for this puppy.
  10. dstrauss
    10,058
    8,247
    Call it sour grapes if you like (because I'm not pre-ordering), but it is long past time that the keyboard and pen gets bundled with these devices, particularly the Pro X where there aren't multiple colors or styles of keyboards or pens. The Surface Pro X is worthless without the pen and keyboard, so quit the mandatory upsales...
