Surface Pro X Discussion Thread (October 2019)
  1. Steve S
    7,633
    3,129
    <<... if I were a casual user and prospective customer and saw this...I would run away and never look back...>>
    ...There are sure to be teething pains as Microsoft attempts to transition to a more mobile architecture. We can only wait and see how chilling these types of limitations are. If Microsoft is able to collect a decent set of applications for the Store, the transition may not be as difficult as this article suggests. Consumer education will also be an important element...
    daddyfish likes this.
  2. dstrauss
    9,735
    7,709
    Not real appetizing by the sounds of that review
  3. JoeS
    4,846
    2,903
    Right? “No mom, listen: using WOW64, an x86 emulator, ARM chips can run 32-bit apps, but not all 64-bit versions. The Surface Pro X can natively run 64-bit apps but only those that have been ported to ARM64, an evolution of ARM that supports 64-bit processing. How are you not getting this?!
    dstrauss likes this.
  4. Marty
    3,158
    2,773
    'Uh so, so now can you explain this "USB-C" thingy? What can I plug into this?' :D
  5. dstrauss
    9,735
    7,709
    Lord, you two are a whinny pair of curmudgeons......welcome to the club! :D
    JoeS likes this.
  6. wataru
    367
    269
    Maybe it's because that they use anodized aluminum on the Pro X instead of VaporMag on the Pro?
    Here is a past reference regarding the original Surface RT -
    If it is indeed the material of the casing that leads to the weight gain, then why Microsoft chooses aluminum this time for their shining new toys (don't they want lighter devices)? It could also be that the battery is heavier than the motherboard on the same footprint (assuming the Pro X has a larger battery)?
  7. desertlap
    1,518
    1,666
    This discussion here and on the other tech sites reminds me of a joke I heard when I first started working for a technology company.
    Q: What's the difference between a technology salesman and a used car salesman?
    A: The used car salesman knows he's lying
    Bronsky and dstrauss like this.
  8. desertlap
    1,518
    1,666
  9. dstrauss
    9,735
    7,709
  10. daddyfish
    daddyfish Pen Pal - Newbie
    44
    , if they use alum., perhaps they are doing it because black on magnesium scratches off more easily? A more energy dense battery could indeed be the case, though usually with such advantages there are also disadvantages in batteryland. I was also thinking that perhaps they changed something to the screen to make it more durable or such. (though this just reminded me that one would expect the weight to be even lower since it does not need magnets anymore for the pen because of the keyboard pen cradle)
