Surface Pro X bitlocker issue
Discussion in 'Off Topic Chat' started by Greg Middleton, Apr 16, 2021.
  1. Greg Middleton
    Greg Middleton Pen Pal - Newbie
    So I've locked my Surface Pro X by turning off Secure Boot... and no bitlocker encryption is at hand.. Can I use the USB-C port to boot up the Surface image from a USB key with ann adapter (USB-C to USB)? Stressing... apologies if the wrong area. Without a bitlocker key I appear to be in trouble unless that will work. I assume I can't boot from a regular USB port on the dock..
  2. jnjroach
    4,133
    1,561
    Here is where you can find your Bitlocker Key - Finding your BitLocker recovery key in Windows 10 (microsoft.com)
    Use an 16GB USB C Thumb drive to put the Pro X Recovery Image on and you should be able to get your device back up and running. Also, I don't recommend turning off secure boot :)
  3. Greg Middleton
    Thanks for the advice. Never screwing with Secure boot again! All good now.. I found the key in Azure. :)
    Bronsky and jnjroach like this.
