Surface Pro Hard Reset
Discussion in 'Microsoft' started by razielu, Sep 8, 2014.
  1. razielu
    razielu Pen Pal - Newbie
  2. jnjroach
    4,150
    1,606
    Shut the machine completely down (if machine is unresponsive, hold power button down 20-30 seconds until it shuts down), hold the volume rocker up and power on, exit the UEFI Screen without changing anything....
  3. razielu
    And should that operation cut off power across the board (just like pulling out the battery would)?
  4. jnjroach
    4,150
    1,606
    It is more akin to the "Soft Reset" on a Smartphone. It clears the RAM and caches of any data....
    What are you trying to accomplish?
  5. razielu
    I'm trying to reset USB power state. In other words, do a full USB power cycle in other words. Usually that helps when the USB port gets hung up (it spits out code 43 for every device you connect to it).
    On a laptop with a removable batter you'd just disconnect the power cable, take out the battery and then hold the power button for 10-20 seconds to discharge all remaining power from within the condensers on the board.
  6. jnjroach
    4,150
    1,606
    It should accomplish what you're looking to do
  7. razielu
    It hasn't. Already tried that. :)
  8. jnjroach
    4,150
    1,606
    You do realize that the USB Port on the SP3 is under-powered and the error you're seeing is more likely caused by that, most of us have circumvented this by using Y Cables, plugging the power portion into the Power Supply's USB Charger.
  9. razielu
    First of all, I have a 1st gen. Surface Pro, and second it worked like a chaem up until the 8.1 update. Is your solution also applicable to SP1? Thanks.
    Edit: Just tried a Y cable, same symptoms.
  10. jnjroach
    4,150
    1,606
    This should work on all Surface Pro models...do you have any pending Firmware Updates?
