Surface Pro 7 Discussion Thread (October 2019)
  1. excalibur1814
    2,332
    307
    I need reviews. I NEED... to read reviews.
  2. Steve S
    7,637
    3,134
    <<...I NEED... to read reviews...>>
    ...No, you don't. You already know you want them to have your money...
  3. sonichedgehog360
    2,022
    1,521
    Yesterday, I just demoed the Pro 7 again and the Laptop 3 for the very first time for another Cinebench run. Unrelated to that, I learned the Laptop 3 happens to have a Qualcomm Atheros Wireless AC chip (I didn't note the exact model), so no Marvell there, either, thankfully. I downloaded Cinebench R15 onto both of them to do a quick head-to-head. The Pro 7's Wi-Fi 6 chip, the Intel AX201, was noticeably quicker at downloading over the Best Buy Wi-Fi connection than the Laptop 3. Though this was but a brief demo session, my best Wi-Fi reliability and throughput has consistently been with Intel Wi-Fi chipsets. The Pro 7's Wi-Fi was easily the best Wi-Fi experience I have ever had on a Surface. Returning to the reason I demoed the Surfaces, here are their test results in Cinebench R15 (single core/multi-core):
    i5 Model Surface Pro 7 — 168/723
    Ryzen 5 Model Surface Laptop 3 — 146/714
    Test conditions:
    Both were run cold in high performance mode. Cinebench R15 was set in Task Manager to highest priority.
    bloodycape and Marty like this.
  4. Steve S
    7,637
    3,134
    [UPDATED 16Oct19-A] Now that there's been some time to do some research, and thanks to information provided by members like @sonichedgehog360 , I think we can now better define the value proposition for the Pro 7 relative to the Pro 6. It turns out that there's a little more going on under the hood than we were first told.
    For the purposes of this post, I'm only going to cite the i7 details; except for the processor, the other details almost certainly apply to the i5 model and probably to the i3 model as well:
    What is different about the i7 Pro 7 relative to the i7 Pro 6
    Processor... Ice Lake 10th Gen i7-1065G7 versus 8th Gen i7-8650U - 10th Gen will provide a nice performance bump
    Graphics.... Intel Gen 11 Iris Plus versus Intel UHD Graphics 620 - Iris Plus almost twice the power of UHD Graphics 620?
    RAM...…….. 3733MHz LPDDR4x versus 1866 MHz LPDDR3 - Significantly faster RAM
    WiFi………… WiFi 6 802.11ax (Intel AX201 chip) versus WiFi5 802.11ac (Marvell chip) - Intel AX201 should provide significantly faster and more reliable WiFi performance
    TPM...……. TPM in Firmware (no chip) versus TPM 2.0 chip - Microsoft claims the firmware implementation makes updates easier with no decrease in security over a physical chip
    In addition, the i7 Pro 7 features:
    • Studio mics for better clarity sensing the human voice
    • USB-C 3.2 Gen 2 (10 GB/s) and DP 1.4 in place of the mini-DisplayPort; can run 2 4k displays at 60 Hz. Can charge the Pro 7 (60 W: 20V @ ~3A to as low as 7 W: 5V @ 1.5A when Pro 7 is off) and can power other devices such as a cell phone (5V @ 1.5A; 7.5W)
    • USB-A 3.1 Gen 1 (5 GB/s)
    • BlueTooth 5.0
    • Fast Charge from ~5% to ~80% charge in about one hour
    • Updated display that is brighter (450 nits?) yet also more power efficient
    • Improved Hello camera
    • Type Cover features a larger touch pad with better "click;" key travel and tactile feel the same as SP6 Type Cover
    So, rather than just a simple processor upgrade, it appears that the Pro 7 features a more global upgrade of its system architecture and power system. Hopefully, that makes the Pro 7 a little more attractive to those who may be pondering a purchase.
  5. bierot
    bierot Pen Pal - Newbie
    95
    28
    Another interesting feature, according this source:
    https://mspoweruser.com/the-new-surface-pro-7-will-support-usb-c-charging/
    is that "...you can use a standard USB-C charger to charge the new Surface Pro 7. Even some portable power banks can be used to charge this device."
    Marty and sonichedgehog360 like this.
  6. sonichedgehog360
    2,022
    1,521
    Many monitors--including the P27u-10 I just received yesterday in the mail--also supports a display connection and device charging simultaneously via USB-C. One cable to rule them all!
  7. JoeS
    4,848
    2,903
    Does that one connection also allow the use of a couple of USB ports on the monitor? Because in that case people won't even have to buy a dock anymore, the monitor IS the dock.
  8. sonichedgehog360
    2,022
    1,521
    Short answer: yes but with a possible caveat. Long answer: Due to the bandwidth limitations of USB-C, you have to choose between operating at 4K 60Hz and only having USB 2.0 speeds or operating at 4K 30Hz and having full USB 3.1 speeds.
    It is not a deal breaker if you are just using a USB keyboard and mouse, but add wired gigabit ethernet or high speed external storage to the mix and this could end up being a problem. Keep in mind this only applies to monitors supporting 4K resolutions and above that have USB-C connections with power sharing. By the way, with a Thunderbolt 3.0 monitor, you wouldn't have this problem which is why some people are peeved Microsoft did not just go all in and make that port Thunderbolt 3.0-capable. Of course, that then would eat into their beloved Surface Dock sales if they allowed Thunderbolt 3.0 docks and monitors to steal the spotlight and we wouldn't want that, would we? ;) Then again, if Microsoft sold an Xbox-/Surface-branded Thunderbolt 3 GPU enclosure (given that this year I am also refreshing my desktop, I would have strongly considered consolidating my desktop and Surface into a single device), I think they might have been able to recoup a lot of these losses.
    dstrauss and JoeS like this.
  9. dstrauss
    9,742
    7,719
    If only it had the Surface Pro X screen and Thunderbolt 3 - what a wonderful world this would be...
    cbutters, JoeS and sonichedgehog360 like this.
  10. Bronsky
    7,682
    4,143
    Herman's Hermits.
