Surface Pro 7 Discussion Thread (October 2019)
  1. jangaru
    jangaru Pen Pal - Newbie
    23
    Has anyone seen crashes in Desktop Window Manager and Surface Service on Reliability Monitor? When I do, I get one-two second video card crashes usually right when I use my pen. Thankfully hasn't happened today, though it was bad yesterday (one whole minute) on a clean install of 20H2.
    I have also seen jittery screen/blurry text during Zoom calls (+ OneNote and Word or Word and Edge are also open) when connected to a second screen. A restart usually makes it go away. Strangely enough no logged events in Reliability Monitor nor Event Viewer.
  2. ElectronicFur
    ElectronicFur Pen Pal - Newbie
    93
    So I'm thinking of replacing my SP4, the one with failing battery, for an SP7. I think the SP4 going to fail soon, as now the screen has started having yellow streaks on both sides, which I read is from the battery expanding.
    My SP4 is 16GB i7 512GB, and I'll need something similar in spec. I'm not really up to date with the latest tabletpc's. As well as the SP7 what competitor's tabletpc's with similar form factor would you recommend I consider? Are there any with user replaceable batteries? Or does nothing else come close to the SP7, and I should just not waste my time looking at anything else?
  3. JoeS
    5,659
    3,975
    Good question! If you want a kickstand and a detachable keyboard, I think the Surface line still rules that land. Anyone else have any suggestions?
  4. excalibur1814
    2,376
    361
    Wait a little bit longer for the SP8! Hopefully, by then the price of the SP7 will fall.
    darkmagistric and cbutters like this.
  5. Variable
    Variable SiteCharts.com
    404
    Hopefully there will be some good deals now.
  6. darkmagistric
    3,092
    2,254
    Thats my plan. My Pro 5 still works, and as much as I want that stupid USB-C port, (USB-C chargers all over the house) my Pro 5 still works fine as is, I'd rather wait till the 8.
