  1. jyan_osu
    jyan_osu Scribbler - Standard Member
    407
    115
    Mine is the i7/8GB/256GB version. I might install the beta intel drivers if i keep getting the black screen of death
  2. bierot
    bierot Scribbler - Standard Member
    102
    28
    No issues when updating my Surface Pro 4 m3. 1% of battery drain every 50 minutes with Wifi off when in Sleep mode.
    Less artefacts with Firefox, but still some ones.
  3. mertzi
    mertzi Pen Pal - Newbie
    43
    I've had really bad sleep drainage and have relied on hibernate. After installing the latest updates and changing every related power setting to sleep it dropped from 70% to 68% in 4 hours. Although I'm not sure it really was sleeping because when I pressed the power button it didn't react at first and then when holding it for maybe a second I got the login screen and had to type my password despite having set "Password protection on wakeup" to "Don't require a password". So it might have shut down even if I changed all related power settings to sleep.
  4. dstrauss
    12,363
    11,831
    That's why I'm holding off pulling the trigger - Iris Graphics still worry me...
  5. Dayton
    Dayton Scribbler - Standard Member
    230
    24
    Why if you can install a driver from Intel if you don't like the one from MS?
  6. jnjroach
    4,150
    1,606
    Just to level set, no Connected Standby machine "Sleeps" (which is traditionally S1 through S3 Power States, S3 being the most modern Sleep State). Connected Standby enabled Intel SoCs use S0iX which a superset of the S0 Power State (Powered On). S0iX is a Powered On Low Power State that is akin to an ARM based phone or tablet.
    So technically the machine is on and can still carry out functions (like receiving mail, Skype Calls, etc.). Because Win32 is a legacy programming environment, it is not able to function in the S0iX Power State, so as a work around all Win32 Programs are forced into a virtual S3 State. WinRT based apps can remain functional.
    Win32 Applications/Programs can misbehave and refuse to go into the virtual S3 state preventing the device to go into S0iX which causes the power drain. Also, with SkyLake Intel struggled with getting their SoCs to enter into DRIPs which allows for the lowest power levels.
    The Surface Engineering team took it one step further and defaults their devices to use Hibernate after 120 minutes on the SkyLake/Cherry Trail (Win 10) devices or 240 minutes on Haswell/Cherry Trail (Win 8.x) devices.
  7. Dayton
    230
    24
    I don't like the settings to be inaccessible, such as those for Power and Scaling.
  8. Dayton
    230
    24
    Still receiving updates so looks like MS is still tweaking things. One thing I may try depending on the amount of battery drain during Sleep is to disable Windows Hello.
  9. dstrauss
    12,363
    11,831
    So does that mean the 1-4% drains being reported are for two hours, not the full shutdown period reported?
  10. dream3
    321
    14
    Guys, please post the sleep report stating if you have hibernate after 120 minutes which should be the default. Otherwise people might think it spent the whole night sleeping when it actually hibernated after 2 hours.
