  1. dream3
    321
    14
    Guys, changing the subject a bit, quick question:
    Just got my surface pro 4, i5/8 gb/256 gb. I set it up and it installed critical updates. Now should I hit the Defer option or should I go ahead and update everything I can?
    Lot number is 1548.
    Secondly, any other important step I should take in order to make things as smooth as possible with the surface? Talking about settings/software issues.
  2. dstrauss
    11,044
    9,612
    @dream3 I assume by "critical" you include Win 10 Pro v1511. If so, and everything is running well, you can defer upgrades (which will still send you virus updates) - remember deferral is approximately four months from release, so if the mythical power fix is issued, you may want to let it run in the wild for a few weeks; watch this site like a hawk; then lift the deferral embargo to update yours.
  3. dream3
    321
    14
    haha thanks dstrauss. That makes sense. How do I know whether I have 1511 installed or not? Maybe it deferred that one as well?
  4. metalsiren
    856
    262
    run winver it will let you know the version.
  5. dream3
    321
    14
    Im still on version 10240.
  6. alextrela182
    1,440
    566
  7. dream3
    321
    14
    But do I even want version 1511? Or should I stick with 10240? One hour sleep drains about 2%, much less than what people are reporting.
    And I cant really use windows update because it will push the newer updates, like the 01/27 firmware one.
  8. dstrauss
    11,044
    9,612
    1511 was a good improvement for me, but if you are only losing 2% per hour - you may want to just wait for the "final" upgrade...
  9. alextrela182
    1,440
    566
    Well if with 10240 you are total fine stay over there,but I don't know if staying the previous build version will be able to get important cumulative Windows update that maybe needed 1511 version to be installed.
    And those cumulative update bring many improvement under the hood with the optimization of the core of Windows 10 OS.
    And there is no final version of 10 because OS acting as a service with all the time getting upgrades for example RedStone and so on over the next years.
    Sent from my iPad Air 2
  10. dstrauss
    11,044
    9,612
    Sorry - didn't mean "final" as in the final version of OS X (oh, sorry, I meant Windows 10 - they confused me there for a minute - LOL); I meant final in the sense of the power upgrade for Skylake - the "hard science problem"
