Surface Pro 3 problem with external DVD drive
Discussion in 'Microsoft' started by scrambler, Jul 10, 2014.
  1. daver
    759
    72
    I've been using the default Windows burning software/module and it works just fine. I just had to ensure that I had the power-only side of the Y-cable plugged into the AC adapter.
    Without the power plug, the drive loses power every 5-6 seconds then gets power again. I'm assuming that the USB power on the SP3 provides less than 850mA, because my drive claims that it requires 850 mA to operate.
  2. scrambler
    301
    19
    Interesting you say that. When I connected my external drive with a single USB cable, I did not get any error message, it just would not work.
    When I first plugged in my powered USB Hub and plugged my drive into it, I got your error message about power surge on USB port. After a few tries, I unplugged the hub from the tablet, plugged in the drive in the Hub and in the power supply, then plugged everything in the Tablet and it worked.
    So try different sequence as it may work in the end.
  3. AndyME
    AndyME Pen Pal - Newbie
  4. vancamp
    vancamp Pen Pal - Newbie
    I used a y cable and an external backup battery (eachine ultra-slim 7000mAh) and Pioneer BDR-XU03 to watch a Blu-ray movie last night. Completely portable... no wall power. However, it did take the extra battery juice to get the drive to be stable.
    Sent from my Surface Pro 3 using Tapatalk
  5. cbroughton
    cbroughton Pen Pal - Newbie
  6. Nepheler
    Nepheler Pen Pal - Newbie
    Using external disc drive to play DVD on surface can be tad obtuse. I'd rather rip my DVD collections together with Blu-rays. Try some dvd ripping tools and you'll no longer need the external drives. I'm using free DVDAid, the free version may not do a very decent job but enough for me.
  7. jolinzhu520
    jolinzhu520 Pen Pal - Newbie
  8. jolinzhu520
    I would appreciate if you can provide the following Information to help us understand the issue better.
    1. Does the external DVD player has separate power supply?
    2. Have you checked if the issue persist while the Surface Pro 2 is plugged into an AC Source?
    Since the Surface Pro 2 is initially not designed to run DVD player and burn CDs, the external DVD drives connected through USB do not get sufficient power supply through ports to perform those tasks.
    DVD players usually read discs at a constant linear rate. The disc's rotational speed varies from 25.5 Hz (1530 RPM) when reading at the innermost edge, to 10.5 Hz (630 RPM) at the outer edge.
    If the DVD player does not get sufficient power supply to make the required RPM (Revolutions per Second) it can’t read the disc or if reads the disc can’t perform other related tasks.
  9. scrambler
    301
    19
    As I explained earlier, this was eventually solved by using a powered HUB
  10. Davidjk58
    Davidjk58 Pen Pal - Newbie
