Surface Pro 3 Discussion Thread
Discussion in 'Microsoft' started by JoeS, May 20, 2014.
  1. dbrn
    447
    144
    Thanks Joe. I've already tried all of those steps except a reset (and cleaning - I'm not so clever) and the problem persists.
  2. JoeS
    6,362
    5,163
    Ugh.. TBH it doesn't really sound like a problem that can be fixed with a factory reset, but I've been wrong before. I wonder if you can test it without resetting your machine by running Windows from a bootable USB. If the problem persists in pre-boot environments (e.g. BIOS) or when running from USB, it seems more likely that it's a hardware issue.
  3. sonichedgehog360
    2,803
    2,843
    Doesn't the BIOS menu have a touch interface? If the ghost touch happens there as well, it has to be a hardware issue.
    dstrauss likes this.
  4. dbrn
    447
    144
    Wish I'd read these before I did the reset, because the problem did indeed persist in the BIOS menu, and, now, post-reset. Now I have a reset machine AND the touchscreen HID turned off so that at least I can use the pen/kb without constant interference. Awesome. Think I'll go see how effective punching yourself in the face is for traveling backwards in time.
    JoeS likes this.
  5. SAM 2013
    859
    221
    Update:
    I have solved my problem for the moment,
    in case someone else has the same problem.
    Recalling the DOS days, when there was problems,
    we would run SFC (system file checker)
    I scanned the files using Command prompt SFC and
    apparently there was some corrupt files that it repaired
    enough for it to boot.
    Don't know if this is temporary or if this fixed the problem.
    Boot up Problem
    I'm having boot up problems to my start screen.
    First press of the power button results in either a black screen(mouse cursor is visible)
    or a partial 1" black strip on right hand edge and bottom left hand corner.
    I can reboot and get a full star screen, no problems.
    Do you think this is hardware or software problem?
    Thanks
  6. MacrosTheBlack007
    MacrosTheBlack007 Scribbler - Standard Member
    143
    Curious, were the throttling issues ever "fixed" on the i5/i7 models to the point where you can play games without FPS plummeting?
  7. Steve S
    8,808
    4,555
    <<...were the throttling issues ever "fixed" on the i5/i7 models...>>
    ...Yes, in the sense that after a few cycles of updates, the throttling behavior was much less objectionable. I still use my Pro 3 to play (not very demanding) games and the throttling is no longer a problem.
    As for more demanding games, I can't really comment. Perhaps another forum member has an opinion?
  8. MacrosTheBlack007
    143
    That's great to hear! I have a friend looking at a Surface Pro 3 i7 model. He likes to play games such as Starcraft 2, Diablo 3, Civ 5/6, etc.
  9. Kumabjorn
    4,604
    2,927
    I discovered a new problem that I can't seem to rectify on my own. After the Creators Update the old basic Windows screen saver is no more, and I can live without it. However, I thought it was and that it had been reset to basic blacj. Despite keeping the SP3 connected and setting alla power settings to remain on (screen, network etc) all four screens turn black when I'm away for a while (my guess is att 30 minutes, could be an hour) and the worst part is that it also turns off WiFi, despite all my Power settings are to the contrary.
    Does anyone know what is going on here? It really wreaks havoc on my OneNote syncing.
  10. SAM 2013
    859
    221
    My USB port has seemed to quit recognizing anything.
    It just keeps saying "USB Device not Recognized"
    I have tried to remove the USB controller and such in Device Manager
    My USB sticks and drives work on other computers.
    Is my USB port gone out, or is there something else I can try?
    Thanks
