  1. bloodycape
    2,813
    429
    The two reviews I saw were of the i5 model, which say battery life is around 7-8 hours. I am wondering what the battery life is like on the M3 model. Is it possible it's 9 hours since that is the Y series cpu and no the U in the i5 and i7 models?
  2. Steve S
    8,313
    3,820
    Just installed Sketchable and paired the Dial. Voila! The Dial now interacts with the screen a la Studio! Place the Dial on the screen and you get the surrounding adjustment rings!
    JoeS, Omazic.iv and southdunes like this.
  3. convergent
    405
    71
    Is it practical to use like that? Seems like it takes up so much of the screen. I wish they would come out with a "mobile" Dial that was at least 1/2 the diameter of the current Dial to use on the SP. I think it would be much better and would buy one in a second.
  4. Steve S
    8,313
    3,820
    <<...Seems like it takes up so much of the screen...>>
    ...In truth, it does. It strikes me as more of a novelty than a practical implementation...
    surfaceproartist likes this.
  5. surfaceproartist
    2,930
    1,893
    To add insult to further new Surface pen-related injury, the tips are not compatible with previous generation replacements. The old tip shaft diameter appears to be slightly too wide.
  6. surfaceproartist
    2,930
    1,893
    Hey @Steve S, I know why I buy all these toys I don't have the time to use properly. What's your excuse?
    Bronsky likes this.
  7. Marty
    3,488
    3,455
    Hey guys! Could you test the new Surface Pen on the Z Canvas and see if you notice any hover latency improvements or reduced IAF?
  8. surfaceproartist
    2,930
    1,893
    So far, I can confirm that the new pen with its one and only HB tip requires less IAF than the Surface Pro 4 pen with HB tip on a Surface Pro 3. Comparing the new HB/pen combo with the older pen with 2H nib, the two are neck and neck.
    I'll take a look at the VAIO shortly.
    DRTigerlilly likes this.
  9. DRTigerlilly
    7,594
    749
    301
    would be interesting then to see the new pen with the the 2H nib or something similar.
  10. surfaceproartist
    2,930
    1,893
    As I noted above, the new pen is incompatible with the old tips and only ships with one HB nib. So that comparison will have to wait until Microsoft releases a new replacement tip kit. :(
