Surface Pro 2017 Battery Life
Discussion in 'Microsoft' started by mgerbasio, Sep 7, 2019.
  1. mgerbasio
    334
    114
    Hi,
    My SP is showing the full charge capacity of 34,720 mWh which is 77% of the designed 45,000 mWh. It is still under warranty for about another month. Any idea what MS considers if/when a battery replacement is covered under warranty? Can they replace the battery and not change the entire SP for a refirb or new PC? Thanks.
  2. DRTigerlilly
    7,476
    672
    301
    no the battery cannot be easily changed, if they decided to offer you warranty service you're getting a new to you Refurb.
    Also bear in mind that there is a firmware/software bug affecting Surface batteries right now.
    But definitely try and get it dealt with before your warranty is up.
    nnthemperor likes this.
