Surface Pro 1 Recovery Image....Disappointment
Discussion in 'Microsoft' started by DRTigerlilly, Jun 1, 2020.
  1. DRTigerlilly
    7,572
    737
    301
    decided to reload my ancient Surface Pro 1 (that I've given to my sister...(ecovery cleaning also in process for the SGB12) only to go to Microsoft's site and discover the only image there for this device is Windows 8.1
    REALLY Microsoft???
    Chris_Kez likes this.
  2. JoeS
    5,425
    3,693
    Are you annoyed with the extra work involved? Because it's still possible to upgrade to Win10 for free.
  3. Bronsky
    8,076
    4,932
    I would be. It's a Microsoft device. You should be able to install W10 direct.
    DRTigerlilly likes this.
  4. FZelle
    787
    197
    Why would you be annoyed?
    The recovery image is for recovering the original installation.
    If you want W10, your choice.
  5. negative1
    negative1 Retro Surface fan
    232
    139
    That's what it originally came with.
    What else should it come with.
    I would be wary of installing Windows 10 on it anyways.
    later
    -1
  6. DRTigerlilly
    7,572
    737
    301
    It was already upgraded and running the latest version of windows 10 but when I tried a reset it failed ..and yes I am annoyed at the extra work.
    Why could there not be images for windows 10 for download for the sp1..
    At this point I will just download the ISO instead.
    Sent from my SM-N9600 using Tapatalk
    JoeS likes this.
