Surface Go
  1. lovelaptops
    2,264
    755
    Wow, you're using it in 10s mode? What are the benefits of that?
  2. tcassidy
    tcassidy Pen Pal - Newbie
    50
    I just hadn't bothered changing it. I just now used a Win 7 Pro key and it changed to Enterprise S mode. I'll think about it.
    Terry
  3. Kumabjorn
    4,285
    2,308
    Does any of you Go users know how to remove a BT device from Win S mode?
    I have a keyboard that I connected temporarily to my iPad Pro and when I want to reconnect it to the Go first have to remove it. That works fine in Settings, but not in reality, because after removing it the keyboard will not show up in the scan dialog box. But Win S loads the device driver, tells me it is making the keyboard ready and that it has finished installing its drivers. It then appears in the Settings > Bluetooth listing as paired, but it won't connect.
    I have tried removing it through Device Manager, even removing the Go BT driver and everything reinstalls itself again, even the keyboard driver, although the keyboard isn't even on. In other words, Win S just hides the driver, it doesn't remove it. Thus making it impossible to re-connect the device.
    The only surefire way I've found is doing it in the Registry, but alas, regedit.exe won't run under Win S. I'm at wits end for something as silly as a BT device.
  4. nnthemperor
    1,701
    533
    Speaking of PDFs in edge, lately parts of my annotations have been vanishing after I save them, so I’ve been using DB and Xodo.
  5. tcassidy
    50
    Sorry, I can't help. I did try it with a Logitech K380 and it does not appear in the list after being removed.
    Terry
  6. Kumabjorn
    4,285
    2,308
    Try and turn off BT on your Go and then turn it on again after 15 seconds. Does it appear automatically?
    Sent from my GT-N5110 using Tapatalk
  7. djas
    djas Graffiti User
    618
    481
    Plus another user on Edge full time on Surface 3 & Note 5.
    Bronsky likes this.
  8. Bronsky
    7,601
    4,023
    Yes. I use edge on my Note 5 as well.
  9. desertlap
    1,231
    1,327
    Quck question related to edge on android, Does it have the ability to read epub files like it does on windows?
  10. jnjroach
    3,944
    1,210
    Yes, if you purchased them from the Store...otherwise OneDrive opens them for me without issue...
    desertlap likes this.
