Surface Go
  1. nnthemperor
    1,925
    781
    Ok, I give up! Any recommendations on USB-c chargers that will work with this device. The GB10.6 QC3.0 wouldn't even charge it. I've scoured ebay and Amazon and the more I look, the less I see. What are you guys using to power yours? I just need to have one charger for my GN8 and SG, so I can leave the SG original charger at home.
    Sent from mTalk
  2. darkmagistric
    2,987
    2,143
    That’s one of my biggest beefs with it. All Samsung Chargers and Battery Packs will not charge the GO.....a unfortunate choice since the Galaxy Book 10.6 uses a more powerful core m3....there’s really no reason why it shouldn’t charge the weaker Penguin Gold Go.
    However....while Samsung USB C chargers don’t work.....Higher powered USB-C chargers will....at the very least USB- chargers that are made for 28W range devices. Like the Wacom Mobile Studio Pro USB- C charger will indeed power the GO and Note 8 phone....so I would also imagine USB-C MacBook Pro chargers would also work since MacBook Pros also use 28W range cores. And I haven’t tried it, but I think the Nintendo Switch USB C charger might also do the trick. However...given how large the Mobile Studio Pro Charger And Switch chargers are....it would acctually take up less space to just bring both the Samsung charger and the stock surface Go charger.
    nnthemperor likes this.
  3. nnthemperor
    1,925
    781
    Thanks. That's a real bummer.
    I finally ordered this on Aliexpress. Fingers crossed!
    https://www.aliexpress.com/item/Bas...237.html?spm=a2g0s.9042311.0.0.3da24c4dSA5bhc
    Sent from mTalk
  4. JoeS
    5,473
    3,740
    FWIW, the Lenovo x1 yoga TB charger also works great.
  5. desertlap
    2,464
    3,053
    Discovered this yesterday accidentally when I forgot to grab my go charger but the 18 watt USB-C charger that comes with the new iPad pros is the fastest adapter I've tried with my go. Anecdotally it's about 25% faster even then the Microsoft supplied adapter.
    JoeS likes this.
  6. nnthemperor
    1,925
    781
    Coming from Apple, I'll cost an arm and a leg. I'd rather stick with the original charger from MS
    Sent from my SM-N950F using Tapatalk
  7. desertlap
    2,464
    3,053
    Very true. I had one because I bought a new 12.9 iPad Pro so I guess I really overpaid for it :)
  8. Tams
    Tams Scribbler - Standard Member
    548
    272
    I'd be careful though. If it's heating up the battery more than normal, then it's going to shorten the battery's life.
  9. gpuk
    gpuk Pen Pal - Newbie
    I'm looking at replacing my Dell Venue 11 Pro 7140 8 GB 256 GB SSD with either a Surface Go 8 GB or a refurbished Dell Latitude 11 5175 8 GB. Is the Surface Go a better choice than the Latitude 11 5175?
  10. Bronsky
    8,117
    4,989
    I love my Go. The Latitude outclasses it in CPU power and battery life. But, it's over 3 pounds with the keyboard.:vbeek: I guess it depends on what you're looking for.
