Surface Duo Discussion Thread
  1. jhoff80
    3,448
    1,177
    That's because Microsoft's Outlook app isn't using the Android Calendar storage function. So Outlook's calendar is completely siloed off from the rest of the device, meaning that if you install calendar widgets, or Google Assistant, or anything else, it can't see your calendar events. If you use an app that does use Android's Calendar storage then Google Assistant on the phone can access all of your events.
    That being said, if you use a Google Home device (like a speaker or smart display) that really can only connect to Google Calendar.
    Bishop likes this.
  2. Kumabjorn
    4,391
    2,548
    Now that they are both out I can´t help but think that the Galaxy Fold Z2 5G got the aspect ratio wrong. It could easily be a cm or two (almost an inch for you imperialists) when folded, thus the double when opened without inflicting on the UX, actually enhancing it.
    nnthemperor, dstrauss and Bishop like this.
  3. JoeS
    5,565
    3,852
    I think you a word. Wider? Taller? Thicker? I'm thinking you mean wider.
    Kumabjorn and Marty like this.
  4. Steve S
    8,161
    3,659
  5. Steve S
    8,161
    3,659
    Chris_Kez likes this.
  6. Kumabjorn
    4,391
    2,548
    Yes, wider. Don’t post before your morning cup of Joe.
    nnthemperor, Bishop and JoeS like this.
  7. Chris_Kez
    Chris_Kez Reformed Lumia Fan
    353
    364
    I can't blame them; no one-- at any point-- anywhere, from Redmond to the furthest reaches of the Microsoft fan-base has speculated that this will be some kind of breakout hit. The constant drumbeat is that this is a niche device. Still, it does have echoes of that heartbreaking epic Lumia Owners' Lament.
    Steve S, desertlap and Bishop like this.
  8. desertlap
    2,626
    3,295
    I think there are other factors at play here, first and foremost that a case at least in the conventional sense we are used to with a single slab smart phone don't make as much sense.
    When we were letting select people look at the duo in the company , many found even the MS supplied bumper extraneous. And to go further, use case (pun intended ) makes a huge difference. e.g one case we had basically covered the entire back(s) of the device which was great for using it flat or in "book mode" but was obviously worthless when using it with the second display fully 360 degrees to the other side,.
    Not to mention that despite the real thinness of the device itself, ironically any case, even the very thin ones, felt overly bulky to most who tried it.
    At @Steve S suggestion I ordered a skin for mine and I think that may at least for now be the only workable option for many.
    PS: This is not new, with the iPhone, even Apple as well as many other tried the book type covers that folded over the screen when in your pocket. While they did serve a function in protecting the screen, based on what multiple vendors told us, they sold poorly generally and also had high return rates from those that did buy.
    TLDR: Companies and users are still figuring this out and it's early days, not to mention it's still an unproven device in the broader market.
    darkmagistric and dstrauss like this.
  9. Bronsky
    8,140
    5,027
    Easily remedied.
    lovelaptops, Chris_Kez and dstrauss like this.
  10. Bishop
    778
    1,098
    156
    Agreed @dstrauss, to wit:
