Surface 3 Discussion Thread
Discussion in 'Microsoft' started by yuki, Mar 31, 2015.
  1. Bronsky
    8,593
    5,898
    I actually ran my S3's battery down to >5% today while it was in the Dock! I had the display on 100% and was using the hell out of the tablet as a desktop computer. I never noticed the battery discharging until both screens went blank. I hope MS recognizes that it has a problem with the charging system and works a fix. You should never be able to discharge your tablet while it is in the charging dock. I lowered the display power to half and the S3 has been charging ever since. It's up to 36% ATM.
  2. cliffr39
    cliffr39 Pen Pal - Newbie
    51
    23
    Completely agree. While I loved the Surface 3, I returned it for the charging issue #1. Hoping they release a revised Surface 3 version 2 or something with that charging fixed. May pick it up again.
  3. Mesosphere
    5,320
    2,085
    Ouch. I guess the dock probably isn't providing more power then?
    I think there may be some bug in the S3 charging circuitry that likes to drop the charging current randomly. It will charge at a normal rate and suddenly drop to like a trickle charge. Temporarily unplugging it seems to bring back the full charge rate ... temporarily. Hopefully this is something they can fix in firmware.
    Pushing the S3 to it's limits, the max drain I could obtain is ~11 W, and it charges at about ~9W from the charger. This doesn't include power loss to charging inefficiencies (more power than this exits the USB charger). Still, that is only a 2W difference, so it would take ~14 hours to discharge. Even if we call it 3W it would last ~9 hours (using the S3 to its max, which is hard to do). I suspect that these discharges are due to the S3 negotiating down to a lower current.
  4. soh5
    soh5 Wait and Hope (Bronsky et al.) Senior Member
    1,365
    695
    As much as a universal micro USB is nice, I think it would have made sense to just throw in a proprietary charging system that charges efficiently...
    That is unacceptable that it discharges on the dock. That is concerning...
    Kumabjorn and bloodycape like this.
  5. Mesosphere
    5,320
    2,085
    Except the dock doesn't charge it via mUSB, so I think they effectively are using a proprietary solution through some hack of the USB3 port (or perhaps the display port?).
    (but I agree with your point, I'd prefer the faster charge to the universal aspect I think).
    Edit: Perhaps better yet... they could have went with mUSB3 which can charge faster using a mUSB3 cable, but it is still backwards compatible with mUSB2 chargers.
    bloodycape likes this.
  6. soh5
    1,365
    695
    Do you know what the power draw is from the Dock is rated at?
  7. Bronsky
    8,593
    5,898
    What ever it is, it is a real issue. Here's what tipped me off that it was a charging issue. At first I thought the tablet had shut down due to the heat. I was surprised at how warm the unit got in the dock, driving the 21" display. I expected to see the thermometer icon but got the depleted battery.
    Here's what came up when I tried to restart it. I let it charge up a bit and once it started, I was able to get it charging positively by lowering the display brightness by 50%.
    I hope MS will figure this out before too long. My new set up is great other than the charging issue. I know I'm pushing that X7 quite hard but the Atom really has some heart. It likes to be pushed.
    @casty - the S3 pen looks great in journal. I never use Journal. I always use OneNote for any kind of note-taking.
  8. thierryb
    1,403
    322
    If your tablet was hot, probably the battery was too. And often batteries have circuitry to prevent charging and discharging when hot.
    Bronsky likes this.
  9. alextrela182
    1,440
    566
    If they do that(surface 3 second edition) then they must provide replacement unit to all customers bought the current version.
    Btw for me it's not big deal that takes more time of charging since I don't push to the limit of the device(most of time while charging I'm not using the device or doing light activate like browsing)
    Most of time the brightness level is 25-30% and is very good level I think, don't forget that S3 has much brightest screen than SP3.
    With that it takes 4 hours to be changed from 20% battery level.
  10. dstrauss
    12,363
    11,831
    Wow - what a deal killer if you can't prevent discharge when in the dock. Does it exhibit the same behavior when just plugged into its charger (discharging while using external monitor)?
