Student needs tablet for note taking
Discussion in 'What Tablet PC Should I Buy?' started by dwaynevbrooks, Feb 6, 2010.
  1. dwaynevbrooks
    dwaynevbrooks Pen Pal - Newbie
    General Questions.
    1. What is your budget?
    $1000.00 max
    No
    3. Do you prefer a Slate, Convertible or Ultra Mobile PC (UMPC)?
    Either Slate or Convertible
    Compact ~ 10"
    Mainstream ~ 12.1"
    Large ~ 13.3"
    5. Which country do you intent to purchase from?
    Any
    No
    Min. 3hrs
    Notetaking, Surfing
    No, once it windows compatible.
    Microsoft Office, Autocad maybe
    10. Do you intend on playing Games? If so please list.
    No.
    Screen Specifics
    1. What resolution do you prefer?
    XGA - 1024x768 ~ large and easy to read text and graphic icons but you fit less on the screen.
    SXGA - 1400x1050 ~ Small text and graphic icons which require good vision but the gain is a much larger screen. (no longer available new, must look for used or refurbished machines)
    WXGA - 1280x768 ~ has a wider usable area than XGA, ideal for viewing Spreadsheets and other programs that require desktop space. The mainly used resolution for new tablet PCs since 2008.
    WXGA - 1280x768
    2. Do you require the screen to be readable in sunlight?
    Will be nice
    3. Do you prefer your display to be glossy or matte?
    Matte
    4. Do you require Touch? (without pressure sensitivity) (Which one: resistive or capacitive)
    Yes
    5. Do you require a Pen? (with pressure sensitivity) (Which one: Wacom or N-Trig)
    Yes
    Component Specifics
    Minimum required. Will only be using for note taking then will sync with home PC
    2. Do you require an Optical (CD/DVD) Drive to be built in?
    No. USB a must
    No. Portable battery charger Yes
    Misc
  2. ninetynine
    ninetynine Pen Pal - Newbie
    HP TM2 is pretty much the one and only choice for under $1000.
  3. gaidensensei
    gaidensensei Pen Pal - Newbie
    If it's just simple notetaking with a stylus and typing, minimal web surfing (nothing too crazy like loads of heavily flash based sites), you might want to look into a netbook. Thus you can buy something for cheaper and still have it perform what you need.
    But if you're planning on doing CAD design on a netbook, that's pretty much a red flag. You'd want something of the high performance caliber to get renders and work with minimal nuisances. The upper level of tablets generally cost more than their notebook counterparts.
    Though it's not to say that the netbook has all the features a standard tablet/notebook is capable of. I'm not sure if they have 1280x### resolutions for netbook tablets, that would be a thing to check while looking around.
  4. Frank
    3,847
    116
    The issue with netbooks is that they only have a resistive touchscreen, if they're convertibles. And so they're 'useless' for good note taking.
    A new tablet PC, for less than 1000 USD, yes, the HP TM2 is your only option. Still, the HP2710p, 2730p, Fujitsu T2010/T2020 would be better suited for your needs, but you have to buy them used or refurbished if you don't want to spend more than $1000.
    Touch, none of the above mentioned tablets have an option for it, only the pen.
    If you want touch, then really, the HP TM2 is your only option.
