Student/doodler
Discussion in 'What Tablet PC Should I Buy?' started by donutwant, Jan 10, 2017.
  1. donutwant
    donutwant Pen Pal - Newbie
    I really just need something for general use, which for me consists of common office tasks and single ayer painting in MS or Krita. Also note taking. I've really just been looking at the surface but its pricey and I would like to get the best performance I can. This will be acting as my desktop replacement for a bit, but I don't intend to game on it.
    1. What is your budget?
    <$1000.
    Because I am cheap.
    Really depends on the sort of warranty I might be able to get, or at least how reliable the seller is.
    I honestly do not care too much; I’d like something that isn't super heavy though. A convertible thats a couple years old would work for me, it just needs to have pen input.
    = or >10in, please.
    The USA
    Not really? I'd like a reliable PC that will last at least a year before it implodes?
    The more the better imo
    School work, Linux vm’s, ART <-- important one
    Windows only
    General office tasks(excel, word, email, lync), MS5 (I only ever use three layers at most), google sketch up
    Nope.
    Naw
    Screen Specifics
    The higher the better. Good color representation is pretty integral to me though.
    Outside? What’s that?
    YES!! I’d like wacom or new ntrig preferably.
    Component Specifics
    I’d like more memory, if possible. Also, I’d like as much ram as possible as well.
    Hmmm. I’d like full size?
    Misc
    I’d really like something I can get a warranty on because I am incredibly clumsy. I realize this would limit me to new items, which at my price is dicey. So it's only a preference.
    Nope! A good summation of my desires would be the best performance/screen I can get that has a digitizer (or whatever the kids call em these days.)
  2. thatcomicsguy
    2,657
    1,719
    There are a *lot* of excellent machines which can fit that bill for quite a bit less than $1000.
    I couldn't even start to recommend any particular one. Small screens are not my area of precise knowledge. Hopefully a few members will pitch in with their fave picks.
  3. Shogmaster
    3,756
    1,050
    Miix 700 or 720 would be good except for the color gamut of the screen isn't very high. Surface Pro 4 has high color gamut screen.
  4. artistebot
    319
    323
    IMHO, take a look at what Shogmaster uses.
    It might be helpful to list your needs in order?
    For example:
    Microsoft SP4 might serve best as all around multimedia Windows "do it all" device.
    A Wacom MSP might be best for un-compromised art creation.
    A iPad Pro might be the ultimate mobile sketching device.(not a tablet PC anyway..)
    A Samsung SM-P580 might be a mobile budget art/media device.(not a tablet PC anyway..)
