ST5112 Problem with Hard Buttons
Discussion in 'Fujitsu' started by nerys, Feb 24, 2011.
  1. nerys
    nerys Pen Pal - Newbie
    I have a strange problem with my ST5112 and the "hard buttons" on the edge of the unit.
    sometimes they do not work. at all. I THINK I am noticing a trend now.
    when I turn the machine on from off they work (so far 100% of the time)
    When I "reboot" the machine they FAIL to work 100% of the time.
    NOW note THEY WORK at boot up either way. I know this because I can press the bios or boot button and it works. it also works 100% of the time to let me select xp or 7 (dual boot) was wondering how I would handle that but the buttons work fine during boot.
    but once in windows they WILL NOT WORK if I "restarted" the machine.
    I have to actually power it down to off and then turn it back on. I don't have to pull the battery or anything but I have to shut down not restart.
    once working they stay working. they work fine after suspend etc.. no issues but if I hot restart they FAIL to work when I get booted back up (but still work at bios and boot selection)
    suggestions? my guess is windows is "doing" something hinky on reboot or something.
    Also can I customize the buttons? ie change their function?
    I noticed that the TOP button (A11) ?? at least thats what it seems to say on the button) does not do anything if I press it but if I press and hold it opens task manager.
    can I assign that a key? (like F12 or something like that)
    also anyone got drivers to make the buttons work in windows 7? I get an error on boot and no button access in 7.
Similar Threads - ST5112 Problem Hard
  1. Maxxx70
    942
