solid screen?
Discussion in 'Hardware' started by poetdante, Mar 14, 2006.
  1. theocide
    theocide Pen Pal - Newbie
    well i've got a Compaq TC100 which i'm currently selling because it simply is not powerfull enough. The one thing i did liek about it though is that it had a screen that was solid and only responded to pen input, when (becaus ei do intent to) i het another tablet PC i dont want to have to kind of hover my arm over the screen while i write, i'm a student and use the tablet functions for taking notes. Which, if any of the newer Tablets have solid screenslike this? and are any of the 'soft' screen Tablets actualy ok to rest your arm on?
  2. Daring
    Daring Moderator
    593
    Most tablets use solid writing surfaces. Wacom "Penabled" tablets in particular will all use solid writing surfaces. The only touch screen I am aware of is the Fujitsu P1510 which I have never used, but Barry did a review on it and he may be able to give you some guidance.
  3. theocide
    Well it was just that in a review of the the new hp TC4200 it was mentioned that it might not be suitable for students because the touch sensitive screen didnt work if you rested your arm on it and i was rather disapointed because i'm a student and liked the look of that system, does anybody own one who could comment?
  4. poetdante
    1,042
    r15 works for me. I'm a student.
  5. Daring
    Daring Moderator
    593
    I own a TC4200 and frequently rest my hand/arm on the writing surface exactly as you would a piece of paper. I have tried several other tablet PCs and they all have solid surfaces with the exception of the previously mentioned P1510. Where was the review?
  6. theocide
    Well i cant find the review again so i think i'll go with the opinion of an owner.
    Thanks alot
    *goes off 2 buy new tablet*
  7. poetdante
    1,042
    I hope you are buying an r15.
