Smaller tablet for artist/musician using adobe suite/protoolls
Discussion in 'What Tablet PC Should I Buy?' started by VibeRantLaw, Jan 6, 2013.
  1. VibeRantLaw
    VibeRantLaw Pen Pal - Newbie
    I purchased an iPad mini which was fun but completely useless for my design purposes. I own a Mac but will rely heavily on this tablet because I create on the go.
    1. What is your budget? 800-1000 ( with a 200 extremely worth it allowance)
    2. Would you consider purchasing used/refurbished? Yes
    3. Do you prefer a media/mobile tablet like the iPad, Windows tablet PC, or notebook convertible? Media/mobile
    7.1 to 10-inches
    10 to 13-inches
    5. Which country do you intent to purchase from [where do you live]? US
    6. Do you have any preferences to brand loyalty or dislikes? No
    7. How many hours battery life do you require? At least 3hrs continuous use
    Drawing, photoshop, music editing, note taking, Internet
    9. Do you have an OS preference? For example, do you own an iPhone and a Mac, or are you a Windows fan? Do you own an Android device and use Google services frequently? Own Mac
    10. What software and tasks do you intend to run? Adobe suite, protools, ms office
    11. Do you intend on playing Games? Maybe, rarely
    12. Would you like to stream content through your home theater system? Maybe
    Screen Specifics
    1. Any preference on screen resolution? High :)
    2. Will you be using the tablet outdoors? Do you need to be able to see it through glare from the sun? Not necessary
    3. Do you require a pen? With or without pressure sensitivity? Do you prefer Wacom or N-trig? Yes, yes, unsure
    Component Specifics
    1. What size Hard Drive and Memory do you require? Would you like expandable memory? Enough to run photoshop, illustrator, protools and maintain a decent load of files
    2. What sort of inputs do you require, if any? Would you like full-sized USB and SD card slots? Are microUSB and microSD ok? Do you require HDMI inputs? USB, had I
    Misc
    Art capabilities are more important than music on this device but the combo would be ideal. Need the technology to last a few years
  2. VibeRantLaw
    Edit: Wacom pref for screen specs
Similar Threads: Smaller tablet
Forum Title Date
What Tablet PC Should I Buy? Netbook sized (or smaller) tablet PC with Wacom? Apr 23, 2011
What Tablet PC Should I Buy? Smaller, lighter EP121. Having a very hard time deciding... Mar 10, 2014
What Tablet PC Should I Buy? Need a smaller/lighter replacement for Toshiba M700 Apr 24, 2011
What Tablet PC Should I Buy? From C140X to smaller form-factor Jan 4, 2011
What Tablet PC Should I Buy? Need needed Tablet pc for Art. Yesterday at 10:34 AM
