Small tablet to run a specific application
Discussion in 'What Tablet PC Should I Buy?' started by SaSiNO97_, Jun 20, 2018.
  1. SaSiNO97_
    SaSiNO97_ Pen Pal - Newbie
    1. What is your budget?
    50 to 180 USD per piece.
    No.
    Media/mobile.
    • 5 to7-inches
    • 7.1 to 10-inches
    • 10 to 13-inches
    • Above 13-inches
    5 to 8 inches, it must be enough comfortable to hold on a hand, and interact using the other, and to type using both.
    Italy.
    No.
    At least 8 hours, with Wi-Fi on.
    I am developing an application that only takes input from the user and sends/receives small data packets to/from a central server, without any expensive operation; basically when the user performs certain actions, the machine sends small data packets to the server and when the server has updates, it notifies the machines running this app which will in turn download the data, keeping the network usage to the strict necessary. The server will be located in a local network, not on the Internet. The tablet will only run this application.
    Must run UWP apps, so it must be a Windows 10 device, either Desktop or Mobile.
    See #8.
    No.
    No.
    Screen Specifics
    No. Even 640x480 is OK.
    Maybe. In that case I could use an anti-glare film.
    Not required. Would be nice. Even without pressure sensivity and with a bad precision.
    Component Specifics
    Just the minimum space to allow Windows 10 to run without slowing down, and to install my application. Micro SD slot would be nice, but not required.
    No particular input needed. Just the touch-screen and a micro-USB port.
    Misc
    None.
    - must be impact resistant enough that if it slips from the hands of the user while walking fast, its screen must not break.
    - must NOT FREEZE, its usage must be pleasant, the UI must be always responsive.
    Thank you very much in advance!
  2. Shogmaster
    4,017
    1,295
    Not to be blunt, but anything sub $150 in Windows space today will be running Z8350. You need to embrace the freezes and say goodbye to UI responsiveness at all times.
    Starlight5 likes this.
  3. SaSiNO97_
    Hello, thank you very much for your answer.
    I would like to say that the maximum price is not binding, if there is a machine that matches my description, it would be fine for it to cost even a bit more, like 250-270 USD; sure it is important for it to have a low cost so that my targets will not be discouraged, but it is more important that its lifetime is long and its responivity is good.
  4. Shogmaster
    4,017
    1,295
    I feel like I'm being trolled at this point...
    You need to get into $500 range chief. .
  5. Starlight5
    Starlight5 So what if I'm crazy? The best people are.
    674
    220
    @SaSiNO97_ give some recent Atom/Celeron device a try, ask friends etc - and you'll see if it suits you or not.
  6. SaSiNO97_
    Sorry, I am not trolling anyone sir.
    A low cost atom processor does not necessarily mean that the tablet will get frozen. I don't need a huge computational power, I just need enough power to run Windows smoothly, and not freeze during the normal usage of the said application. That application will be designed to use even less resources than Word and PowerPoint.
    Thank you. I was thinking of course of an Atom device since it needs to be low cost. As for now, after reading reviews, the two options that I am considering are the NuVision 8" and the Chuwi Hi8. If someone on this forum owns one of these two PCs then I'd appreciate to hear their experience.
  7. Shogmaster
    4,017
    1,295
    That was my bad. I think I was confused that you raised only like $25 to your initial budget. Sorry to come off as dickish.
    As for the CPUs, anything under U or Y series Core processors IMO are suspect. We are stuck in a world where Atom and Apollo Lake Celeron/Pentiums bench worse than top end phone processors...
