small tablet but must have stylus and size requirements
Discussion in 'What Tablet PC Should I Buy?' started by wwgg, Jul 26, 2018.
  1. wwgg
    wwgg Pen Pal - Newbie
    1. What is your budget?
    up to $500 but would rather not pay that for something used from 2014.
    yes but only because I'm having trouble finding something new.
    tablet, b/c notebook is too large and heavy for carrying around regularly
    doesn't matter but absolute size can't be more than 6.5" wide or 8.5" tall. Prefer under 6" and shorter than 8.5" since it would otherwise tilt and fall out of my pocket.
    USA
    none
    7-8
    web surfing, notetaking, word processing.
    none
    onenote, web apps
    no
    no
    Screen Specifics
    none
    no
    This is a requirement, must be accurate and fast responding. The black rubber nub pens don't do it for me. How are the ultra fine tip stylus compatible with the ipad mini 4?
    Component Specifics
    I don't know, but expandable memory is preferred.
    HDMI preferred but not required.
    Misc
    Hi, I'm in the medical field and am looking for something that will fit in my coat pocket and can take handwritten notes, run basic windows or apple apps, wifi, surf the web, and respond quickly. I don't have time for web pages to load scripts slowly and expect to do this a lot. While I could sew in a larger pocket, running around all day with a large tablet is unwieldy and pulls on my neck. Because of this, weight and size are very important, and must also have fast and accurate stylus response. Don't care about graphics or games.
    Found this forum because there's apparently a lack of 8" tablets with stylus support. The ipad mini 4 is the perfect size but it doesn't have apple stylus support, and the 9.7" ipad is just too big to fit into my pockets - it will fall out if I bend over. I'd also rather not carry something so big around all day since the weight adds up. Samsung note is too small.
    Would the best solution be an ipad mini 4 with an aftermarket stylus? I also found the samsung tab a with s-pen but can't even find any used for sale. Thank you for any advice!
  2. Iwan
    Iwan Pen Pal - Newbie
    Hi
    try Samsung tab a 8 inch WITH spen, careful with the same version but without spen
    , since you said need for basic task and surf, this tablet can do all thing from mail to simple Ms.excel jobs
    and add some bluetooth keyboard cover, then probably solved all your need
  3. alice123sdfsfd
    alice123sdfsfd Pen Pal - Newbie
    Huawei Tablet M5
    Very satisfied so far!
    I was immediately surprised by the quality of the packaging, it might be an Apple product as far as I'm concerned.
    The tab feels sleek, so smooth and elegant.
    The quality of the screen is great, battery lasts forever, and, I don't know what's wrong with people that complain about not having the headphone out: the tablet comes with a USB-C to 3.5mm adapter!
    Yes, the volume switches need a little getting used to, but overall, they work. I wish they implemented a volume control slide down like for the brightness.
    The stylus is amazing, even though it, too, needs some getting used to.
    kneehowguys likes this.
  4. djas
    djas Graffiti User
    660
    546
    Stylus? Used to own a GTA8SP & GTA10SP. As far as I know, only Samsung tablets (certain models) have active digitizer Wacom EMR. And Yoga Book.
    Edit:
    My bad. There is stylus support but only on the M5 Pro 10' version. Link
  5. djas
    djas Graffiti User
    660
    546
    I agree. The GTA8SP is a fantastic, portable tablet although it is now 3 years since its released.
    Or maybe the rugged Galaxy Tab Active 2? Comes with active stylus too.
    Marty likes this.
  6. Kumabjorn
    4,378
    2,535
    OP sounds like a candidate for the original Samsung Galaxy Note 8, but with today's standards it is on the heavy side. Finding one in good condition will be a challenge and you'd most certainly would need to find a new battery for it and exchange it.
    But if note taking is your primary need, why not check out the Galaxy Note phones. From 5 and forward it should fit your needs and if you need more computer like features the new 9 comes with DeX so you can hook it up to monitor and keyboard in a second.
    WillAdams likes this.
