Small convertible, alternatives to Fujitsu T580
Discussion in 'What Tablet PC Should I Buy?' started by thejaredhuang, Dec 13, 2012.
  1. thejaredhuang
    thejaredhuang Pen Pal - Newbie
    1. What is your budget?
    <600
    Would prefer it to be used/refurb
    It needs to have a keyboard
    5 to7-inches
    7.1 to 10-inches
    USA
    Not in this case
    Surfing, Word, watching movies
    Windows 8 Pro
    Windows 8 Pro
    No
    No
    Screen Specifics
    At least WXGA, 1280x800
    no
    I do require that i'll be able to trigger it with my finger.
    Component Specifics
    7mm or 9.5mm SATA required.
    HDMI preferred
    Misc
    no slates please, no Atoms unless they are dual core
    I know the T580 fits the bill but I can't find any that I like right now for the right price. I was wondering if there were other tabs out there. The Gigabyte one is too much $$$ right now as well as hard to find. The Acer W500 is something I looked at also but the battery life seemed too poor.
  2. thejaredhuang
    no suggestions?
