small apps
Discussion in 'Windows 8' started by stupots, Mar 18, 2016.
  1. stupots
    stupots Pen Pal - Newbie
    hi i have a lynx 7" tablet running on windows 8.1 i have manged to bypass the login screen ,changed the folder and text size on the desk top, resize the metro tiles ,but cant seen to change the size of the apps, or unpinned apps the text is so small can any one please help
    thanks
    stupots
  2. Twosteps
    Twosteps Pen Pal - Newbie
    I think the app becoming small automatically may be caused by R980, which is reported by this article that it is a malware. Don't hesitate to remove it if it is on your phone.
  3. johnniewalk
    johnniewalk Pen Pal - Newbie
    As per my knowledge, the actual reason for that is the app has been developed for particular device and they have been already coded, so you can't able to change anything inside the app. Only you can change able to move the app were you want to be placed in your gadget.
