Sleeve/Case?
Discussion in 'Dell' started by jhoff80, Oct 23, 2008.
  1. Diduknowthat
    Diduknowthat Pen Pal - Newbie
    14
    What's a good slim sleeve/case for the XT?
  2. jhoff80
    3,640
    1,442
  3. dmlerner
    dmlerner Scribbler - Standard Member
    109
    I love my waterfield. It's pricey, but extremely well made and good looking. There's a good review on here somewhere if you care to hunt it down.
  4. gohanssjn
    gohanssjn Scribbler - Standard Member
    179
  5. jhoff80
    3,640
    1,442
    I just received my Zeroshock case, and its a perfect fit and feels very high quality.
    http://shinza.com/product_info.php?cPath=5_10_15&products_id=76
    That's the one I have, though I bought mine on ebay. I realize that it says 290mm maximum length and the XT's length is 297mm. I was a little concerned as well, but it fits fine. There is also a 13" notebook model of the Zeroshock which would be slightly larger if you're concerned about that.
    I have the thicker model XT with the DLV screen. Just be advised you probably won't fit the charger in this thing. I have the 45watt charger, and the actual brick fits in the outer pocket just fine, but the cables for both ends are just a little too bulky for me to use that for them.
