Simplified: HP tx series batteries lineup (tx1000/2000/2500)
Discussion in 'Hewlett Packard' started by RaidenWoW, Aug 9, 2008.
  1. pilotleston
    pilotleston Pen Pal - Newbie
    Thanks for your help.
    Would you mind telling me whether the code I posted corresponds to the 4 or 6 cell?
    Regards.
  2. jwfisher
    jwfisher TabletPC Enthusiast
    I saw a 12 cell at Frys last night... will that monster fit?
  3. miner
    miner Scribbler - Standard Member
    276
    No, the tx series can only use the above pictured 4, 6 & 8 cell batteries.
  4. bilgia
    bilgia Pen Pal - Newbie
    24
    tilting machine up is a bit useful cos then u dont have to look directly down when in tablet mode.
  5. .me
    .me Pen Pal - Newbie
    Good day! Would it be possible for you to test the battery life and the weight of those batteries?
    I am (and i guess most of us are) interested in in internet-on surfing, writing, checking email etc battery life.
    or lets say - just idle and a movie from a dvd.
    Thanks
    Andrew
  6. dnacid
    dnacid Pen Pal - Newbie
    I am also using the 8 cell battery and I am very glad of the choice made. The 8 cell rises the base up on the back, allowing for more comfortable typing when in laptop form and easier reading when in tablet.
    Although it does add a bit of weight on it (imagine 2 extra AA batteries), it makes almost no difference when you are carrying it.
    With the additional battery life and ease of use, I think the tiny extra weight isn't something I care at atll.
  7. ROGUEx360
    ROGUEx360 Pen Pal - Newbie
    Does anyone know somewhere that sells these 3 different batteries in the UK for a reasonable price? I seem to remember seeing the 6 cell on the HP website for about £79 which seems quite excessive to me.
    I would ideally like one of each size, for different situations, sometimes where weight is the issue, sometimes where endurance is the issue, so it would be good if there was somewhere cheaper to buy them.
  8. bilgia
    24
  9. ROGUEx360
    I do not know if that 12 Cell Battery is compatible, BUT, I have seen reference to a HP Official 12 Cell in this PDF Datasheet for the TX2510ca:
    http://h20386.www2.hp.com/CanadaStore/images/tx2510ca.pdf
    In the option accessories section it lists:
    HP 12-cell Li-Ion Replacement Battery- EV089AA
    So this may mean it is possible to get one, as it lists a part number.
  10. chihping
    chihping Pen Pal - Newbie
    29
