Searching Tips
Discussion in 'EP121 Slate' started by CF77, Jun 8, 2011.
  1. CF77
    2,303
    Here is a tip to do searching in forum as I always have hard time to search old threads..
    Use Google
    type the following in
    site:tabletpcreview.com/ep121-slate/ [keyword you want to search here]
    It is a bit long but works..
    for Moderator-- may be add this to the new user guide..
  2. BlacKnight
    184
    Thanks of a great tip. It works well on this forum, but not on other similar forums that require login :(
    +1
    IMO This should definitely go in the newbie guide.
  3. Roobuls
    Roobuls Pen Pal - Newbie
    21
    Try this:- site:forum.tabletpcreview.com/ep121-slate/ [yourword]
  4. Steve S
    7,884
    3,387
    <<...for Moderator-- may be add this to the new user guide...>>
    ...Strangely, I think that DRTigerLilly did! I had the need to perform a search about a week ago and remembered this search tip, but couldn't find the original post (...if only I could have searched for it...! OK, enough of the irony...)
    Instead, I found a post by DR mentioning the tip. The strange thing is that I swear I saw this in the Help forum, but now I can't seem to find it there...?!??
  5. ifonline
    ifonline Pen Pal - Newbie
    Is the search around here ever going to be fixed?
  6. CF77
    2,303
    We are hoping..
  7. dbrn
    447
    144
    Agreed - thanks CF77!
  8. DRTigerlilly
    7,561
    735
    301
    until we're able to get the issue sorted out, please use the following link to search the forums. I've also made a general announcement. Temporary TPCR Forum Search
  9. JustDavid
    JustDavid ASUS EP121 Slate user
    178
  10. DRTigerlilly
    7,561
    735
    301
    If you clicked the link you'd see instead of having the search string after which you type your own search...This is a Custom Google Site for our Forum. (with added refinements for the more popular forums)
    Which should make it a little easier for those of us not technologically inclined.
Similar Threads - Searching Tips
  1. doobiedoobiedum
    435
