Searching Tablet for Digital Art and reference Portfolio mainly
Discussion in 'What Tablet PC Should I Buy?' started by Aranel, Nov 5, 2012.
  1. Aranel
    Aranel Pen Pal - Newbie
    1. What is your budget?
    I'm relativly open, but I would prefer it not to be over 700€ (which would be iPad3 64GB Wifi category)
    I think so, but I'm a bit suspicious about ebay or similiar sites.
    I prefer an iPad like tablet, cause it should be mobile and handy.
    5 to7-inches
    7.1 to 10-inches
    10 to 13-inches
    Above 13-inches
    I would say something between 10 and 13 inches. But I would consider a different size if any ony recommends it, cause of reasons.
    No, not really. I'm not very fond of android but I want a good tablet.
    As much as possible, 3h min.
    I would use it to carry reference photos and I also consider starting my art digital. Just the regualr (home) wifi thing will be enough, I would love mobile internet but I have no extra money every month to spent on it.
    I own an iPhone and an Acer Laptop running Win7. So I have no prefence, but it should be compatible with Windows.
    No clue. any suggestions?
    No, not as a primary criterion.
    Screen Specifics
    Not really, should be ok for my purpose.
    Yes I think so. But I would be ok with a screen protection.
    Yes, and I would love one with pressure sensivitiy if possible. I never used N-trig but I love my Wacom Bamboo Fun.
    Component Specifics
    It's enough already if I can connect it to my Pc.
    I fancy an iPad3 atm cause fellow artists I know did recommend it but I'm not sure if it's ok or good for my purpose and it's quite price-y. I like the iOS cause it's easy to use and enough for a mobile device (in my humble oppinion) and I like the look of it.
    I tried it a few minutes at a friends party and quite liked it but I don't know if it's the right thing longterm.
    thanks in advance, Mareike
