SDHC: DO they work on TX2000???
Discussion in 'Hewlett Packard' started by kohck, Mar 7, 2008.
  1. kohck
    kohck Pen Pal - Newbie
    22
    Just wondering....
    Do the SDHC cards work on TX2000? If yes, what is the maximum class it support?
    I believe the highest class now is class 6. There is no class 8 yet?? IS TX2000 able to make full use of class 6 SDHC?
  2. jberger
    jberger Pen Pal - Newbie
    Yes, they (SDHC) do work, I've got several that I use with the Tx2000. But I have no idea what class.
  3. icebrrrg
    icebrrrg Pen Pal - Newbie
    Whoa ... are you 100% sure on this? I just ordered a tx2510us, and held off on ordering an SDHC card because the HP "live chat" drone said that SDHC was not supported.
    Has anyone got some real-world experience on Class 4 or Class 6 SDHC support on the tx2500 series? I saw these:
    http://forum.tabletpcreview.com/showthread.php?t=15363&highlight=sdhc
    "Media reader: It's right above the express card slot. Reads SD/SDHC/MS/xD/MMC. Reads and writes fast. I feel like it keeps up with the SDHC Class 6 speed without a problem. It does not fit the SD card flush...about 10-15% sticks out, which is really really lame."
    http://forum.tabletpcreview.com/showthread.php?t=15340&highlight=sdhc
    ... but these are for the tx2000 .... Any help would be appreciated. Thanks!
  4. Crito
    Crito Scribbler - Standard Member
    105
    I'm using a 4GB class 6 SDHC card on my tx2500 with Vista ReadyBoost, no problems.
  5. icebrrrg
    Awesome - thanks! I'll order one now.
  6. billycat
    billycat Pen Pal - Newbie
    Also using a 4GB class 6 microSDHC here. With 4GB memory, not much of a boost from Readyboost. If there is any additional responsiveness, it's imperceptible for me.
    I'm thinking of using a Sandisk Ultra microSDHC.
  7. nigel
    nigel Pen Pal - Newbie
    55
    I found a SDHC from costco.com with the following specification.
    ATP 16GB SDHC Class 6 Secure Digital Memory Card
    22.5MB Per Second
    Maximum Transfer Speed
    $94.99
    Do you guys think this SDHC would be helpful for Vista ReadyBoot?
  8. gregh2000
    gregh2000 Pen Pal - Newbie
    37
    Well, you probably don't need any readyboost. Also, the card doesn't go in all the way so if you leave it in there it sticks out a bit. I use a class 6 8gb from my camera in the reader and it works just fine.
  9. Crito
    105
    ReadyBoost helps with 2GB RAM, which is what I have. With 4GB RAM you don't need it.
  10. nigel
    55
    I see. Thank you for the advice!
