Screen Protection and SSD Options for X220T
Discussion in 'Lenovo (IBM)' started by driekus, May 17, 2011.
  1. Shayes
    Shayes Pen Pal - Newbie
    46
    whoa SLC drives are way overpriced for what you get. ive never seen data showing how much longer they live for, but i really dont think it would be worth it to pay 150+ dollars for a 20 GB SLC SSD
  2. Shayes
    46
    probably is the same procedure, but just in case, use the x220 tablet videos
    Service Videos
  3. kamitorial
    kamitorial Pen Pal - Newbie
    25
    Thank You.
  4. FunnyCurrent
    FunnyCurrent Pen Pal - Newbie
    Did the listed dimensions for the Lenovo X220T on Photodon not provide the coverage you desired? I'm trying to decide whether to order a custom cut according to your listed specifications above or just order the pre-measured screen protector for the X220T.
    Also, if your dimensions provide better coverage (Photodon's measurements are a few mm's smaller) maybe someone should email Photodon to change their cut for the Lenovo X220T.
  5. legendaryflatulis
    legendaryflatulis Pen Pal - Newbie
    I ordered mine with the pre-cut X220 tablet on Photodon's website and it fit perfectly. Unfortunately I botched the installation on mine and will have to order another. It wouldn't hurt if they shipped along a practice unit to install first :D
Similar Threads - Screen Protection Options
  1. Steve S
    689
