Screen dims on battery even on 100% brightness
Discussion in 'Lenovo (IBM)' started by vahnwalker, Jul 11, 2007.
  1. vahnwalker
    vahnwalker Pen Pal - Newbie
    25
    My X61 tablet dims the SXGA+ screen's brightness a little when I pull out the AC adapter. This happens despite having custom power settings configured to have 100% brightness on both the battery and Power plugged in.
    Is this normal?
    One other questions is about the "Adaptive display" option on the Advanced power settings. What does this do?
  2. jenarelJAM
    jenarelJAM Scribbler - Standard Member
    299
    I don't know about the Adaptive Display, but I actually just noticed that my screen gets brighter when I plug it in as well, and my settings are the same as yours. Guess it's normal. It was like that on my dad's old laptop too.
  3. Az2002
    Az2002 Pen Pal - Newbie
    This problem was fixed in the new ver of Lenovo Power manager... Use System Update 3 to get it.
  4. g2tl
    g2tl Scribbler - Standard Member
    567
    or go to lenovo's website :p
  5. vahnwalker
    25
    Thanks guys!! I just love this forum :p
  6. Deekity
    Deekity Pen Pal - Newbie
    35
    there's a setting under power management profiles as well. For instance, default on one was 25% brightness. When you use the shorvut keys on the laptop it will dim and brighten the screen just fine - but only to a MAX of 25% brightness of the screens actual capability (ie you're 100% brightness of 25% allowed capability). Which is why things look so amazingly bright plugged in (100% allowed). You can of course adjust it so it will do this under battery - at the expense of battery life.
  7. krypticide
    krypticide Scribbler - Standard Member
    218
    There's also a BIOS setting that dims the screen on battery, even at 100%.
  8. dp22
    dp22 Tablet Fan
    112
    standard operating procedure on IBM's to lower the max brightness when on battery. You can adjust this in the bios as krypticide mentioned.
  9. midhun
    midhun Pen Pal - Newbie
    at last found a working solution
    watch this youtube video
