scratch out gesture
Discussion in 'HP Slate' started by dgeffs, Jan 2, 2011.
  1. dgeffs
    dgeffs Pen Pal - Newbie
    49
    I saw the scratch out gesture used with the slate on one of the OneNote videos. Can't seem to figure out why this won't work on mine. Gestures are enabled so what is the trick?
  2. SimsHsia
    3,293
    Hi dgeffs,
    You need to go left to right with the pen over the stuff you would like to erase about three or four times so that OneNote can recognize the scratch out gesture. Sorta like when you write something incorrectly on a pad of paper and pen, you just scratch it out. OneNote will automatically erase it.
  3. Steve S
    7,179
    2,697
    ...Use three horizontal strokes; be sure you don't inadvertantly lift the pen nib at the end of any stroke.
    Note that in some applications, strike-out has to be enabled (typically in the Options menu...)
  4. dgeffs
    49
    I swear that is what I was doing but it seems to be working now. Perhaps a restart helped. Oh well - thanks.
  5. czm2000
    1,015
    192
    Hey, I know I'm late to the party, but just wanted everyone to know the real trick here is in making sure you stay as close to possible on the same line. I've tried this a dozen different ways. The way it always works without fail for me is to start left to right and to go back and forth 3 or 4 times like SimsHsia, but the key is to try and make your scribbles all over lap like you're trying to scratch it out in one line, if that makes sense? Do that and it will work every time :)
