SciLor's ATI Tablet PC Rotation Fix v0.5
Discussion in 'Hewlett Packard' started by SciLor, Oct 23, 2009.
  1. SciLor
    SciLor SciLor
    49
    SciLor's ATI Tablet PC Rotation Fix v0.5 for Windows XP
    SciLor's ATI Tablet PC Rotation Fix is a tool that enables the Tablet PC auto/button rotation feature of the ATI Catalyst Driver which is disabled by default (Windows XP). You can also change the direction of the rotation (Clockwise or Counterclockwise).
    For example the HP Pavilion tx2000er series needs this fix, otherwise you cannot use the buttons near the screen to rotate the display orientation and you will have to change the display orientation in the driver manually if you put your device in Tablet PC mode.
    Code:
                                i.
                                .7.
                               .. :v
                              c:  .X
                               i.::
                                ..i..
                               #MMMMM
                               QM  AM
                               9M  zM
                               6M  AM
                               2M  2MX#MM@1.
                               OM  tMMMMMMMMMM;
                          .X#MMMM  ;MMMMMMMMMMMMv
                      cEMMMMMMMMMU7@MMMMMMMMMMMMM@
                .n@MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM
               MMMMMMMM@@#$BWWB#@@#$WWWQQQWWWWB#@MM.
               MM                                ;M.
               $M                                EM
               WMO$@@@@@@@@@@@@@@@@@@@@@@@@@@@@#OMM
               #M                                cM
               QM         Another Cake by        tM
               MM              SciLor            CMO
            .MMMM                                oMMMt
           1MO 6MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM iMM
          .M1  BM     For all Portal Lovers!     vM  ,Mt
          1M   @M............................... WM   M6
           MM  .A8OQWWWWWWWWWWWWWWWWWWWWWWWWWWWOAz2  #M
            MM                                      MM.
             @MMY                                vMME
               UMMMbi                        i8MMMt
                  C@MMMMMbt;;i.......i;XQMMMMMMt
                       ;ZMMMMMMMMMMMMMMM@A;.
    ReadMe
    You will need the .NET 3.5 Framework
    SciLor's ATI Tablet PC Rotation Fix is a tool that enables the Tablet PC auto/button rotation feature of the ATI Catalyst Driver which is disabled by default. You can also change the direction of the rotation (Clockwise or Counterclockwise).
    ToDo:
    Known Bugs:
    If you like my hard work PLEASE DONATE! :)
    http://scilor.ac-host.net/donate.html
    ChangeLog:
    v0.5 (2009-10-23)
    -Initial Release
    ---------------LINKS-------------------------
    My Website: http://scilor.ac-host.net/
    SciLor's ATI Tablet PC Rotation Fix Website: http://scilor.ac-host.net/atitabletpcrotationfix.html
    Donation: http://scilor.ac-host.net/donate.html
    Download:
