SC 2200 Pen not working
Discussion in 'Electrovaya' started by P8RSON, Nov 28, 2006.
  1. dans
    dans Pen Pal - Newbie
    Hello
    My pen is not working on my Scribbler. I had spyware on my computer and when I removed the spyware the pen stopped working. I ran the recovery disk and that did not help. I was wondering if any could tell if I missing something here like a setting or how to fix it? Thanks in advance.
    Respectfully,
    Dan
  2. Gautam
    Gautam Moderator
    484
    Check to see if the driver for the pen is enabled/installed/working
    Control Panel > Device Manager > Human Interface Devices >
  3. P8RSON
    5,189
    Failing that, try carrying out a system restore.
    It should be able to pick up an older setting used.
    ...and then tred lightly as you run your spyware remover on the restore.:)
Similar Threads - 2200 working
  1. Steve S
    626
